I have recently installed 12.04 on ASUS-K53SV-V300. I can change the brightness on start-up with:
echo 0 > /sys/class/backlight/acpi_video0/brightness >> /etc/rc.local
or manually by Fn key.
But, whenever Ubuntu dim my screen brightness to save power or wake-up from suspend or inactive for 20-30 seconds, brightness reset to high (my problem get much more when on battery).
How can I disable screen brightness service to prevent it from changing my brightness? What service work on screen brightness? If I disable this service, can I manually set brightness by command?
find a replacement to work on brightness instead of default power manager.
cholazer
  • 91
You can turn off brightness adjustments to save power in System Settings->Brightness and Lock.
Steve Kroon
  • 1,034
In case you don't want your screen to turn off or dim at all, I recommend the tool Caffeine.
sudo apt-add-repository ppa:caffeine-developers/ppa
sudo apt-get update && sudo apt-get install caffeine
If you turn on Caffeine, it will prevent your screen from dimming and switching of. That tool always worked for me.
I have read the core codes of the tool caffeine which written by Python mentioned above and I found the command
$ xset -dpms; xset s off
seems useful.
