I sat down at Starbucks this afternoon to do some work (Ubuntu 12.04 Desktop x64), and got the red-circle-with-white-line error icon in the systray notifying of a package error. Also, apt, aptitude, update-manager, and synaptic were all failing to even start up because of this.
Took a closer look, and the error was:
> sudo aptitude install mmv
[sudo] password for kurtosis:
[ ERR] Reading package lists
E: Encountered a section with no Package: header
E: Problem with MergeList /var/lib/apt/lists/linux.dropbox.com_ubuntu_dists_precise_main_binary-i386_Packages
E: The package lists or status file could not be parsed or opened.
So opened up the culprit, /var/lib/apt/lists/linux.dropbox.com_ubuntu_dists_precise_main_binary-i386_Packages, and lo and behold, the entire file has been overwritten by the html source for Starbuck's ATT wifi terms and conditions page, that you have to agree to by checking the checkbox the first time you log onto their free wifi (first few lines below).
This is extremely bizarre and bit disconcerting, since some random internet site has managed to overwrite a file that should only be modifiable by root. Any idea what happened?
Solved by deleting /var/lib/apt/lists and regenerating with this command:
$ sudo -i
# apt-get clean
# cd /var/lib/apt
# mv lists lists.old
# mkdir -p lists/partial
# apt-get clean
# apt-get update
Starbucks ATT wifi homepage source:
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
<html xmlns="http://www.w3.org/1999/xhtml" lang="en" xml:lang="en">
 <head>
  <title>AT&T Wi-Fi Service @ Starbucks</title>
  <meta http-equiv="Content-Type" content="text/html; charset=utf-8" />
  <link rel="shortcut icon" type="image/ico" href="/favicon.ico" />
  <script type="text/javascript" language="javascript" src="/dhtml/master.js"></script>
  <script type="text/javascript" language="javascript" src="/dhtml/x_core.js"></script>
  <script type="text/javascript" language="javascript" src="/dhtml/x_event.js"></script>
  <script type="text/javascript" language="javascript" src="/dhtml/x_xhr.js"></script>
  <script type="text/javascript" src="/dhtml/aws/dhtml.js"></script>
  <script type="text/javascript" src="/dhtml/jquery/jquery-1.3.2.js"></script>
  <script type="text/javascript" language="javascript" src="/dhtml/jquery/aws_jclock_2.2.0.js"></script>
  <script type="text/javascript" language="javascript">
$(function($) {
        var options = {
                format: '%i:%M<span class="clock_ampm">%P</span>'
        $('.jclock').jclock(options);
  </script>
  <link rel="stylesheet" type="text/css" href="/css/att/themes/sbux/laptop_free_v3.css"/>
  <link rel="stylesheet" type="text/css" href="/css/att/themes/sbux/sbux_auto_addl_v2.css"/>
 </head>
 <body>
  <div id="free_wrap">
   <div id="topblock">
  <div id="topmid">
         <div id="free_sbux_mainform">
          <div id="iframe_free">
          <iframe id="sbux_iframe" src="http://www.starbucks.com/coffeehouse/wi-fi-landing" scrolling="no">
                                </iframe>
          </div id="iframe_free">
          <div id="free_sbux_logo"><a href="http://www.starbucks.com"></a></div id="free_sbux_logo">
         <div id="free_sbux_location"><div id="location_city">PALO ALTO, CA</div id="id="location_city"></div id="free_sbux_location">
          <div id="inline_free_form">
          <div id="free_text_line">Starbucks is pleased to offer complimentary Wi-Fi <b>including the premium content of the Starbucks Digital Network</b> to customers who are enjoying our food and beverages.</div>
bgibson
  • 5,037
Here's what happened.
  • A sudo apt-get update was either performed manually or it was triggered automatically ( Remember the automatic updates from update manager? ) and attempted to refresh the lists.
  • You happened to be connected to the wifi, but did not accept the licence or whatever yet.
  • The wifi was bad enough to send probably a HTTP 301/302 status (redirect) instead of something more appropriate, and apt obediently followed it, dumping the response page in the lists file.
  • It looks perfectly normal, and is due to a misconfiguration of the wifi. Ideally, when you are not yet allowed access, a error code is to be returned so that similar things won't happen. Just for an anology, if you had a script or alternate setup to resume a download whenever you connect to internet, and it starts working when you connect to this wifi and you have not yet accepted the agreement, the tool will dutifully dump the same page and declare that the file has been downloaded, potentially overwriting any previous part of the original file.
If you are connected to internet, It should be perfectly safe to delete the entire folder /var/lib/apt/lists and do a update. That will fix this. To be on the safe side, you may choose to backup instead of delete.
sudo mv /var/lib/apt/lists ~;sudo apt-get update
should do the trick, and if it doesn't, revert back with sudo mv ~/lists /var/lib/apt
Mahesh
  • 13,026
