I just installed Ubuntu today with WUBI. After installing, the first time I tried to boot it, it gave me a screen with this grub prompt:
Minimal BASH-like line editing is supported. For the first word, TAB
lists possible command completions. Anywhere else TAB lists
possible device or file completions.
GRUB>
I tried repeatedly to reboot, and no luck. What is wrong?
Zanna
  • 72,312
James
  • 29
Follow the steps below one by one.
  1. Boot from the Ubuntu Live cd/usb and select "try ubuntu".
  2. When the desktop is loaded, download the boot script. It contains script and a changelog file.
  3. Now cd to the directory of the extracted zip file.
  4. sudo bash boot_info_script.sh The above steps should get you through.
Zanna
  • 72,312
When the machine first froze, did you just switch it off, because you did not know how to regain control? If so, you have probably corrupted the file system and that has apparently prevented grub finding its files.
The first thing to try is to boot from the livecd, open a terminal, type su to become root, enter the root password (root for a standard livecd) when prompted, and then run fsck -fy /dev/sdax where ax is the letter and number of your pclos partitions. To find out which they are you can use fdisk -l (that's a lower-case 'L'). You don't need to (and can't, in fact) fsck the swap, but the / and /home or whatever you have need to be done. They must be unmounted, but should be by default with the livecd. If not, use umount /dev/sdax to unmount them.
BuZZ-dEE
  • 14,533
