I have installed axel and set it to get my firefox downloads through flashgot. It works but the Axel window is not visible - so cannot know when the download starts and ends, its speed etc.
I have recently installed Lubuntu Precise. Before I was using the same but the main installation was Xubuntu and did not have this problem.
Is a window created with other console downloaders? (wget, aria2).
start any long download and run in terminal ps -C xterm,axel ww.Also you can try to run xterm from terminal xterm. Try the following variants:
  1. 'Alt+Tab' to take out the hidden window. Sometimes it helps. But I don't know if this combo works in lubuntu.
  2. Write down a command line for axel manually in the flashgot options.
  3. Reinstall flashgot.
seeline
  • 143
When you initiate the download the status is not shown in the terminal installed in lubuntu, but on 'xterm'. All you have to do is to install xterm:
sudo apt-get install xterm
'xterm' comes installed with Ubuntu and Xubuntu, that's why it worked fine when you had Xubuntu with lubuntu-desktop installed.
green
  • 14,406
