Possible Duplicate:
How to remove desktop environments?
I just installed the MATE desktop following the instructions here but im not satisfied with MATE (actually it totally looks like a mess) so i want to completely remove it from my system... How can i do that? i think its not enough to remove just the mate-core package using apt-get remove ?
thanks
How to remove MATE from Ubuntu
If you want to remove MATE Desktop, you can use the following command:
sudo apt-get remove atril atril-common caja caja-common engrampa engrampa-common ffmpegthumbnailer-caja libcaja-extension libmarco libmate libmate-common libmatecanvas libmatecomponent libmatecomponentui libmateconf libmatecorba libmatedesktop libmatekbd libmatekeyring libmatemenu libmatenotify libmatepanelapplet libmatepolkit libmateui libmatevfs libmateweather libmateweather-common marco marco-common mate-applets mate-applets-common mate-backgrounds mate-conf mate-conf-common mate-control-center mate-corba mate-core mate-desktop mate-desktop-common mate-dialogs mate-icon-theme mate-keyring mate-media mate-menus mate-mime-data mate-panel mate-panel-common mate-polkit mate-power-manager mate-power-manager-common mate-screensaver mate-session-manager mate-settings-daemon mate-settings-daemon-common mate-settings-daemon-gstreamer mate-system-monitor mate-terminal mate-terminal-common mate-text-editor mate-themes mate-vfs mate-vfs-common mate-window-manager python-mate
If you've install the extra MATE packages (mate-desktop-environment), use the following command to remove them:
sudo apt-get remove libmatesensorsappletplugin mate-calc mate-desktop-environment mate-netspeed mate-sensors-applet mate-system-tools mate-utils mozo python-mate-menu system-tools-backends
Source
Seth
  • 59,332
LnxSlck
  • 12,456
Run the following command:
If you ran "sudo apt-get install mate-desktop-environment" to install MATE, run this command to remove extra packages:
mblasco
  • 2,307
