I have Crashplan and it is constantly running in the background and making backups every 15 minutes. It caused some problems with the backup target folders, so I want it to be inactive while I am making changes to these folders.
I started the application itself, but could not find some kind of "Pause" button. So I decided to just stop its process. I first tried the lazy way - the system monitor in the Gnome panel has a "Processes" tab - but didn't find it listed there. Then I did a sudo ps -A and read through the whole list.
I don't recognize everything on the list (many process names are self-explaining, like evolution-alarm, but I don't recognize others like phy0) but there was nothing which sounded even remotely like crashplan. But I know that there must have been a process belonging to Crashplan running at this time, because the main Crashplan window was open when I ran the command.
Do you have any advice how to stop this thing from running? The best solution would involve temporary preventing it from loading on boot too, since I may need to reboot while doing the maintenance there.
Hee Jin
  • 886
rumtscho
  • 1,051
From the Crashplan website it looks like it should be starting a process from /etc/init.d at bootup. I would look in /etc/init.d to see if there are any startup scripts that look like they are for Crashplan. You can easily temporarily prevent a startup script from running at boot time by running:
sudo update-rc.d script-name disable
Where script-name is the name of the script you see in /etc/init.d that you want to disable. It can be re-enabled later by running:
sudo update-rc.d script-name enable
This will put things back the way they were before you disabled the script.
Also, the website says you can stop crashplan temporarily by running:
sudo /usr/local/crashplan/bin/CrashPlanEngine stop
The path is dependent on where you installed crashplan and will probably only stop the currently running process.
One last thing. I find that ps -ax provides more information than ps -A and can be useful when trying to find a running process, especially when the output is piped to grep. If I were looking for a process associated with crashplan I would try a command like this:
ps -ax | grep Crash
I hope this helps!
