Everytime i open Sublime , these tabs automatically opens. How do i fix this. I am unable to find any setting for this.
There is actually a better solution implemented in Sublime Text. Select Preferences-> Settings - User and set remember_open_files and hot_exit to false. The resulting file should look like this:
"remember_open_files": false,
"hot_exit": false
(All the possible settings can be seen in Settings - Default.)
Just restart Sublime Text afterwards (it may be required to restart the program two times, one time to apply the settings) and it should start up without any open files.
Note: I only was able to test this with Sublime Text 3, but I am pretty sure that this settings exist in version 2 as well.
- 591
Sublime Text 2
Check the content of the directory ~/.config/sublime-text-2/Settings for a file called Session.sublime_session
If those files are included in there, remove them
Sublime Text 3
ST3 stores the session files under:
~/.config/sublime-text-3/Local/Session.sublime_session
- 21,763
- 1,356
In Sublime Text 3, below worked for me.
$ rm ~/.config/sublime-text-3/Local/Auto\ Save\ Session.sublime_session
- 179
