I am trying to install Gmsh in 12.04 x64:
xxx@sjb-linux:/320/installslinux/gmsh$ sudo apt-get install gmsh
Reading package lists... Done
Building dependency tree
 gmsh : Depends: libmed1 (>= 3.0.3) but it is not going to be installed
I have now tried all the advice I could get
sudo apt-get -f install
sudo apt-get clean
with no success, these commands report absolutely no problem.
I'll appreciate help.
Tim
  • 33,500
gmsh won't install because libmed1 won't install either. The problem is that there is a conflict with different versions of package libhdf5.
So in order to fix it
  • Open synaptic and searched for libhdf5
  • Then install libhdf5-openmpi-1.8.4, this will remove some of the libhdf5 packages and IIRC some octave-3.2 packages too.
After that I went on to install libmed1 and once that was done I was finally able to install gmsh.
So far I haven't had any further problems related to this.
devav2
  • 37,290
Problem is that gmsh having dependencies those having their own dependencies. So include the not going to be installed package to the main installation list.
sudo apt-get install gmsh libmed1
