The problem is that I can't remove the gnome-shell and gnome-shell-extensions. When I try to delete with Ubuntu Software Center there is an error:
Package dependencies cannot be resolved
This error could be caused by required additional software packages which are missing or not installable. Furthermore there could be a conflict between software packages which are not allowed to be installed at the same time.
Details:
gnome-shell-extensions-user-theme:
And when I try to delete with terminal:
araqkh@araqkh-U30Jc:~$ sudo apt-get purge gnome-shell-extensions
[sudo] password for araqkh:
Reading package lists... Done
Building dependency tree
gnome-shell-extensions-user-theme : Depends: gnome-shell-extensions-common but it is not going to be installed
E: Error, pkgProblemResolver::Resolve generated breaks, this may be caused by held packages.
OS: Ubuntu 12.04 TLS
How can I solve this problem?
