Hugin (panorama stitcher): Any help?
===> hugin
/usr/share/hugin/data/plugins/woa.py
   CAT:Control Points
   NAM:Warped Overlap Analysis
   fails @api-max
/usr/share/hugin/data/plugins/top_five.py
   CAT:Control Points
   NAM:keep 5 CPs per image pair
   fails @api-max
/usr/share/hugin/data/plugins/crop_cp.py
   CAT:Control Points
   NAM:Crop Control Points
   fails @api-max
/usr/share/hugin/data/plugins/shooting_pattern.py
   CAT:initial distribution
   NAM:6-1-1 Shooting Pattern
   fails @api-max
The program 'hugin' received an X Window System error.
This probably reflects a bug in the program.
The error was 'BadRequest (invalid request code or no such operation)'.
  (Details: serial 1148 error_code 1 request_code 154 minor_code 19)
  (Note to programmers: normally, X errors are reported asynchronously;
   that is, you will receive the error a while after causing it.
   To debug your program, run it with the --sync command line
   option to change this behavior. You can then get a meaningful
   backtrace from your debugger if you break on the gdk_x_error() function.)
Linux e520 3.2.0-30-generic-pae #47-Ubuntu SMP Wed Aug 15 18:52:06 UTC 2012 i686 i686 i386 GNU/Linux
guettli@e520:~
Ubuntu 12.04.1 LTS (GNU/Linux 3.2.0-30-generic-pae i686)
Braiam
  • 69,112
guettli
  • 1,765
If you have an ATI card, you can try to deinstall the fglrx package and install the fglrx-update package.
Peachy
  • 7,235
  • 40
  • 47
With or without fglrx-update I had several errors. Not only hugin, other apps, too. I installed Ubuntu 13.04, and the problems are gone. The root of the problem is still unknown, but I don't care any more.
guettli
  • 1,765
