Possible Duplicate:
Do maintenance releases appear in the Ubuntu website
I'm trying to see if the first point release 12.04.1 is ready, but I can't tell from the Ubuntu web site. I'm running 10.04 in some labs and according to Ubuntu we should wait for the first point release before we upgrade from 10.04 to 12.04.
There's no way to answer this question in a lasting way. As of Aug. 23, 17:15:32 UTC, the bits are not available.
Run do-release-upgrade -c to check.
Update
By the way, according to Why is "No new release found" when upgrading from a LTS to the next? do-release-upgrade -c will output "No new release found" until 12.04.1 is available, even if you're on 10.04.x. This is because 12.04 is considered a devel release.
As of Aug. 23, 19:21:03 UTC, I'm seeing "New release 'precise' available" which I assume refers to 12.04.1.
G-Wiz
  • 184
I'm using 10.4, and 12.4.1 has finally appeared in Update Manager. I had to set the settings to "LTS Releases only" or it only showed 10.10. Now I upgrade.
I intially though this had already been released, and I have been corrected. The .1 version has only been out since August 17. (I was told by several people that it was out far before that -- I'm sorry that my information was incorrect.)
I found this sub-domain of Ubuntu's site that shows current and past releases of Ubuntu: http://releases.ubuntu.com/
You can update via Terminal by following this tutorial: http://www.liberiangeek.net/2012/04/upgrade-to-ubuntu-12-04-from-ubuntu-10-04-via-the-terminal/
belacqua
  • 23,540
pgrytdal
  • 794
12.04.1 has been ready since August 17 http://releases.ubuntu.com/12.04.1/ Thought a torrent download became available just on August 23.
Andy
