Possible Duplicate:
How can I install Sun/Oracle's proprietary Java 6/7 JRE or JDK?
I want to make server with Xubuntu but i don't know anything about Linux, So is there any software which can install Java Jre 7 automatically. -Windows uses too Much Ram-
I think this is what you want. Run the following command in Terminal.
sudo apt-get install openjdk-7-jre
Quick tip
When you're searching for a program like this, try the following command:
apt-cache search keywords here
So for instance,
apt-cache search jre 7
Gives this:
icedtea-7-jre-jamvm - Alternative JVM for OpenJDK, using JamVM
openjdk-7-jre - OpenJDK Java runtime, using Hotspot JIT
openjdk-7-jre-headless - OpenJDK Java runtime, using Hotspot JIT (headless)
openjdk-7-jre-lib - OpenJDK Java runtime (architecture independent libraries)
openjdk-7-jre-zero - Alternative JVM for OpenJDK, using Zero/Shark
You may then use common sense to figure out which package to install.
SirCharlo
  • 40,096
