I just installed SSH and I would like to set it up to only accept connections from localhost. I plan to point a .onion address to it so that I may connect to it from anywhere on any network.
Asked
Active
Viewed 2.9k times
21
In the /etc/ssh/sshd_config file there are those fields :
# Use these options to restrict which interfaces/protocols sshd will bind to
#ListenAddress ::
#ListenAddress 0.0.0.0
Change #ListenAddress 0.0.0.0 to ListenAddress 127.0.0.1, taking note to remove the leading #.
Then run sudo reload ssh and you will be able to connect only from localhost.
Oli
- 299,380
Cédric Julien
- 2,857
Another solution:
add the following line to the file /etc/hosts.deny:
sshd: ALL
add the following line to the file /etc/hosts.allow:
sshd: localhost
January
- 37,208
Plus you should read about iptables.
You can block connection to your host on port 22 via iptables:
# iptables -I INPUT -i eth0 -p tcp --dport 22 -s 0.0.0.0/0 -j DROP
# iptables -I INPUT -i lo -p tcp --dport 22 -j ACCEPT
And read about TransparentProxy.
Anyway solution with /etc/ssh/sshd_config, better.
innocent-world
- 596
