I have several problems with my ubuntu 12.04, which I think interrelated. My first problem is that recently my kernel got updated to 3.2.0-29 (I'm not sure whether it was just generic or generic-pae). Since then my virtual box was not loading displaying an error code Kernel driver not installed (rc=-1908). So, I tried many work arounds, suggested in several threads with no use. I tried to remove, reinstall virtualbox from different sources, no use. When I looked at my synaptic and found that old kernels to be present (3.2.0-27 & 26). In the event of removing them, thinking that they may be causing problem with virtualbox, I accidentally removed my all the kernels, so I couldnot boot. Hence I followed method adviced in this thread How to restore a system after accidentally removing all kernels? (detail method). I didn't know which kernel to install. As my pc has more than 3gb ram, i used generic-pae.
So now when I boot my computer everytime, I'm prompted to grub2 loader menu asking which kernel to use. But I have only one kernel. It also asks whether I should repair kernel (but repair doesnot work, it displays same menu again). I updated grub, but no use. I want to your help on this. I want my laptop to boot & load automatically.
Second is if I run virtual box it displays same error code, described earlier. If I run sudo modprobe vboxdrv the problem gets solved for this boot. But when I reboot, same problem with virtual box.
I greatly appreciate your assistance on this.
Thanks in advance
kums
  • 51
As for the Virtual Box, try the following.
sudo apt-get install --reinstall virtualbox-ose-dkms
Read carefully what the command returned. If it says anything along the lines that it cannot compile the driver, you will have to install the linux header files manually. First, find out what the kernel version is:
uname -r
It will show you something like that:
2.6.32-42-generic-pae
Then, install the headers and reinstall the dkms again:
sudo apt-get install linux-headers-2.6.32-42-generic-pae
As for your GRUB trouble, try to reinstall grub:
update-grub
What is the output of that command?
January
  • 37,208
