17
i was trying to run
sudo rm -r ./tmp
but instead typed
sudo rm -r /tmp
Will it be fixed by running?
sudo mkdir /tmp
if i do what permissions should i give it?
ps: i didnt log out of my system yet
I can't think of a reason why this shouldn't work. On my system, the permissions are set by:
sudo chmod 1777 /tmp
(drwxrwxrwxt)
StarNamer
  • 2,897
10
You should run the following commands to restore the tmp folder.
sudo -i
# You now have a root prompt and do not need to continue typing sudo
mkdir /tmp
chmod 1777 /tmp
exit
Then you sould be all good
Alex L.
  • 3,468
  • 22
To add to Alex's answer, you can do both those commands at the same time using the -m or --mode option for mkdir(1), which specifies the mode for the created directory:
-m, --mode=MODE   set file mode (as in chmod), not a=rwx - umask
So the command would be:
sudo mkdir -m 1777 /tmp
strupo
  • 41
