711
I would like to write a bash script to decode a base64 string. For example I type decode QWxhZGRpbjpvcGVuIHNlc2FtZQ== and it prints Aladdin:open sesame and returns to the prompt.
So far I have tried a simple bash file containing python -m base64 -d $1 but this command expects a filename not a string. Is there another non-interactive command (not necessarily in a Python module) that I can run from the command line to achieve this, without having to install any extra packages? (Or if I do, something super-minimal.)
A.B.
  • 92,125
lofidevops
  • 21,912
8 Answers8
1047
Just use the base64 program from the coreutils package:
echo QWxhZGRpbjpvcGVuIHNlc2FtZQ== | base64 --decode
Or, to include the newline character
echo `echo QWxhZGRpbjpvcGVuIHNlc2FtZQ== | base64 --decode`
output (includes newline):
Aladdin:open sesame
January
  • 37,208
140
openssl can also encode and decode base64
$ openssl enc -base64 <<< 'Hello, World!'
SGVsbG8sIFdvcmxkIQo=
$ openssl enc -base64 -d <<< SGVsbG8sIFdvcmxkIQo=
Hello, World!
EDIT: An example where the base64 encoded string ends up on multiple lines:
$ openssl enc -base64 <<< 'And if the data is a bit longer, the base64 encoded data will span multiple lines.'
QW5kIGlmIHRoZSBkYXRhIGlzIGEgYml0IGxvbmdlciwgdGhlIGJhc2U2NCBlbmNv
ZGVkIGRhdGEgd2lsbCBzcGFuIG11bHRpcGxlIGxpbmVzLgo=
$ openssl enc -base64 -d << EOF
> EOF
geirha
  • 47,279
53
Here you go!
Add the following to the bottom of your ~/.bashrc file:
decode () {
  echo "$1" | base64 -d ; echo
Now, open a new Terminal and run the command.
This will do exactly what you asked for in your question.
SirCharlo
  • 40,096
27
With your original dependencies it is possible to do this with a minor modification to your original script:
echo $1 | python -m base64 -d
If you don't pass a file name, that python module reads from the standard input. To pipe the first parameter into it you can use echo $1 |.
AmanicA
  • 1,887
22
I did comment base64 command line in http://wiki.opensslfoundation.com/index.php?title=Command_Line_Utilities. So I issue a Warning when using openssl base64 decoding :
 openssl base64 -e <<< 'Welcome to openssl wiki'
 V2VsY29tZSB0byBvcGVuc3NsIHdpa2kK
openssl base64 -d <<< 'V2VsY29tZSB0byBvcGVuc3NsIHdpa2kK'
warning base64 line length is limited to 64 characters by default in openssl :
 openssl base64 -e <<< 'Welcome to openssl wiki with a very long line
 that splits...'
 V2VsY29tZSB0byBvcGVuc3NsIHdpa2kgd2l0aCBhIHZlcnkgbG9uZyBsaW5lIHRo
 YXQgc3BsaXRzLi4uCg==
openssl base64 -d <<< 'V2VsY29tZSB0byBvcGVuc3NsIHdpa2kgd2l0aCBhIHZlcnkgbG9uZyBsaW5lIHRoYXQgc3BsaXRzLi4uCg=='
=> NOTHING !
to be able to decode a base64 line without line feed that exceed 64 characters use -A option :
openssl base64 -d -A <<<
Welcome to openssl wiki with a very long line that splits...
This is anyway better to actualy split base64 result in 64 characters lines since -A option is BUGGY ( limit with long files ).
Seth
  • 59,332
Using perl
perl -MMIME::Base64 -ne 'printf "%s\n",decode_base64($_)' <<< "QWxhZGRpbjpvcGVuIHNlc2FtZQ=="
Or the same with python
python -m base64 -d <<< "QWxhZGRpbjpvcGVuIHNlc2FtZQ=="
A.B.
  • 92,125
Just to add another way to do it:
emacs -Q --batch  -eval '(princ (base64-encode-string (read-string ": ")))'
erjoalgo
  • 1,051
I had a few moments of hair-pulling on this one because the base64 Linux tool and also the openssl can decode, indeed. But I have this particular base64 encoded file that decodes to slightly wrong value. The few bytes do match, but then there is this presence of EF BF BD EF BF BD when I view in hexedit viewer. And then the next sequence of bytes match again when compared to the correctly decoded expected output. These weird sequence of bytes got inserted in the in-betweens, sometime as EF BF BD only.
To resolve the matter, I have to look how the Java sender encodes it and then I created a small java base64 decoder. And now I can decoded to the expected value.
Here is the small snippet that does it: https://gist.github.com/typelogic/0567cdab6c15487c31496cb90006ff52
daparic
  • 358
