I need to run dosemu with nice --20 from script. Problem is: a negative value can be applied only with sudo.
Do you know any way to run nice command without sudo or simply run nice --20 dosemu from script?
guntbert
  • 13,475
Unfortunately, I don't think that's easily doable.
If your dosemu process runs as a separate user, then you can set the priority of all processes of that user to a negative value using /etc/security/limits.conf.
EDIT: silly me, you cannot create a suid shell script, that just doesn't work.
EDIT2: OK, you can configure sudo such that it does not require you to give password when someone from the sudo group runs nice or renice. In a terminal window, enter
sudo visudo
This will open a simple text editor that will edit the configuration of sudo. Add the following line at the end of the file:
%sudo   ALL = (ALL) NOPASSWD: /usr/bin/nice,/usr/bin/renice
Exit the editor. The editor will make sure that the syntax is correct (otherwise one could break the system). Now, you can run
sudo nice -n -20 sudo -u $USER /some/program
and you will not get prompted for a password. In fact, nice will start another process called sudo with the -20 priority. This new sudo process will switch back to your original user (-u $USER, otherwise you would run the /some/program as root) and starts /some/program.
January
  • 37,208
try this:
sudo -k nice -n -20 su -c "dosemu" $USER
while it is running, run this:
ps -A --forest -o pid,user,command |grep dosemu
you will see that nice was run with root privileges, but dosemu was run as normal $USER.
Understandind how safe it is: to make it sure that there is no flaw, try this where you will see it asks the password 2 times because sudo ls is run as normal $USER, so a script with sudo on it wont work unseen:
sudo -k nice -n -5 su -c "sudo ls" $USER
and this will ask password one time only as it is already root to sudo ls:
sudo -k nice -n -5 su -c "sudo ls" root
PS.: instead of dosemu, for tests, I used sleep 120, and sudo -k is for increased safety.
Try: sudo -s -H
It logs you in as root after which you won't need the sudo.
Then run your script.
Seth
  • 59,332
