How can I fix my Software center? I can't update Ubuntu or anything without getting an error that items cannot be installed until the package catalog is repaired. Below is the errors I get. Please help I'm a noob Ubuntu.
installArchives() failed: dpkg: error processing libqt4-xmlpatterns:i386 (--configure):
libqt4-xmlpatterns:i386 4:4.8.1-0ubuntu4.1 cannot be configured because libqt4-xmlpatterns:amd64 is in a different version (4:4.8.1-0ubuntu4.2)
dpkg: error processing libqt4-xmlpatterns (--configure):
libqt4-xmlpatterns:amd64 4:4.8.1-0ubuntu4.2 cannot be configured because libqt4-xmlpatterns:i386 is in a different version (4:4.8.1-0ubuntu4.1)
No apport report written because MaxReports is reached already
dpkg: dependency problems prevent configuration of libqt4-declarative:i386:
libqt4-declarative:i386 depends on libqt4-xmlpatterns (= 4:4.8.1-0ubuntu4.2); however:
Version of libqt4-xmlpatterns:i386 on system is 4:4.8.1-0ubuntu4.1.
dpkg: error processing libqt4-declarative:i386 (--configure):
dependency problems - leaving unconfigured
libqt4-declarative depends on libqt4-xmlpatterns (= 4:4.8.1-0ubuntu4.2); however:
Package libqt4-xmlpatterns is not configured yet.
dpkg: error processing libqt4-declarative (--configure):
dpkg: dependency problems prevent configuration of libqtgui4:i386:
libqtgui4:i386 depends on libqt4-declarative (= 4:4.8.1-0ubuntu4.2); however:
Package libqt4-declarative:i386 is not configured yet.
dpkg: error processing libqtgui4:i386 (--configure):
libqtgui4 depends on libqt4-declarative (= 4:4.8.1-0ubuntu4.2); however:
Package libqt4-declarative is not configured yet.
dpkg: error processing libqtgui4 (--configure):
dpkg: dependency problems prevent configuration of libqt4-designer:
libqt4-designer depends on libqtgui4 (= 4:4.8.1-0ubuntu4.2); however:
Package libqtgui4 is not configured yet.
dpkg: error processing libqt4-designer (--configure):
dpkg: dependency problems prevent configuration of libqt4-designer:i386:
libqt4-designer:i386 depends on libqtgui4 (= 4:4.8.1-0ubuntu4.2); however:
Package libqtgui4:i386 is not configured yet.
dpkg: error processing libqt4-designer:i386 (--configure):
dpkg: dependency problems prevent configuration of libqt4-help:
libqt4-help depends on libqtgui4 (= 4:4.8.1-0ubuntu4.2); however:
dpkg: error processing libqt4-help (--configure):
dpkg: dependency problems prevent configuration of libqt4-opengl:
libqt4-opengl depends on libqtgui4 (= 4:4.8.1-0ubuntu4.2); however:
dpkg: error processing libqt4-opengl (--configure):
dpkg: dependency problems prevent configuration of libqt4-opengl:i386:
libqt4-opengl:i386 depends on libqtgui4 (= 4:4.8.1-0ubuntu4.2); however:
dpkg: error processing libqt4-opengl:i386 (--configure):
dpkg: dependency problems prevent configuration of libqt4-qt3support:i386:
libqt4-qt3support:i386 depends on libqt4-designer (= 4:4.8.1-0ubuntu4.2); however:
Package libqt4-designer:i386 is not configured yet.
libqt4-qt3support:i386 depends on libqtgui4 (= 4:4.8.1-0ubuntu4.2); however:
dpkg: error processing libqt4-qt3support:i386 (--configure):
dpkg: dependency problems prevent configuration of libqt4-scripttools:
libqt4-scripttools depends on libqtgui4 (= 4:4.8.1-0ubuntu4.2); however:
dpkg: error processing libqt4-scripttools (--configure):
dpkg: dependency problems prevent configuration of libqt4-scripttools:i386:
libqt4-scripttools:i386 depends on libqtgui4 (= 4:4.8.1-0ubuntu4.2); however:
dpkg: error processing libqt4-scripttools:i386 (--configure):
dpkg: dependency problems prevent configuration of libqt4-svg:
libqt4-svg depends on libqtgui4 (= 4:4.8.1-0ubuntu4.2); however:
dpkg: error processing libqt4-svg (--configure):
dpkg: dependency problems prevent configuration of libqt4-svg:i386:
libqt4-svg:i386 depends on libqtgui4 (= 4:4.8.1-0ubuntu4.2); however:
dpkg: error processing libqt4-svg:i386 (--configure):
libqt4-xmlpatterns
libqt4-declarative
libqtgui4:i386
libqtgui4
libqt4-designer
libqt4-help
libqt4-opengl
libqt4-opengl:i386
libqt4-scripttools
libqt4-svg
libqt4-svg:i386
Error in function:
SystemError: E:Sub-process /usr/bin/dpkg returned an error code (1)
