I am using a Dell 19 inch LCD monitor.Every time I boot, I get output at 1368x768, 60Hz. In my display settings I have set "Laptop" to 1024x768, but my monitor is compatible with 1368x768 (16:9). How can I set the resolution to 1368x768?
My graphics card is the nVidia GeForce 7025/nForce 630a, on an Asus M2N68-AM Plus motherboard.
Jorge Castro
  • 73,717
Try this it will give you the latest drivers I could not use 1080p 60hz until I got the latest driver
Open a terminal and add the PPA
sudo apt-add-repository ppa:ubuntu-x-swat/x-updates
Then update the repos
sudo apt-get update
And finally update the drivers
sudo apt-get dist-upgrade
Now reboot, and when you log back in you will have a working, up to date nvidia driver in Ubuntu ;)
Heres the original post
Also make sure you are root in the nvidia settings
sudo nvidia-settings
Also make sure the two screens are separate X screens as your resolution will be limited to the lowest one (the laptop) if not.
Hope this helps and good luck.
Mark Kirby
  • 18,949
  • 19
  • 79
  • 116
Set it to extend display (the mode where you can drag between them) , not duplicate, as in display duplication mode they must be at the same resolution.
