I'm using wubi at the moment and my pc is really slow, is it worth deleting XP and formatting it to Ubuntu? Or (trying) to reset XP to factory settings?
PS: I have over 40 GB HARD DRIVE and hate having xp on my computer...
Thanks, DJ Porter
nanofarad
  • 20,906
The difference between the different desktop environments (Unity, KDE, Xfce, LXDE) concerning the amount of resources used is very important, more important than that involved by an application or other. For example, with just 1 gb of RAM, Unity and KDE are not good options, almost beyond reach, while Xfce works decently, and lxde flies. If you have less than 1 GB of RAM, go with LXDE/Lubuntu. So, while you should try a dual boot, try first Xubuntu or Lubuntu in wubi.
What are the specs of your computer? If you're new to linux, the best way to begin, is having a dual boot Ubuntu and Windows XP.
As the time passes, and you become more productive with Ubuntu, you could then remove Windows.
If you run Ubuntu and Windows on dual-boot, one OS won't interfer with the other, the only downside is disc space.
So i would say, dual boot Windows and Ubuntu, there's no need to remove Windows, unless you have litlle disc space.
If you dual-boot and still Ubuntu is slow, i recommend using a lighter distribution of Ubuntu like XUbuntu (Ubuntu with XFCE), or LUbuntu (Ubuntu with LXDE).
In the other hand, if you really like Unity, try running your current Ubuntu with Unity 2D or Gnome Fallback Session.
LnxSlck
  • 12,456
You can run Ubuntu from a live CD or USB stick, without any need to install it to your hard drive first. Try it out and see!
Robie Basak
  • 15,910
Installing Ubuntu on a seperate partition will speed up your machine, so it's definitely worth trying, but it won't make your computer super-fast. (The docs suggest that 500Mb of RAM is needed to run Ubuntu well, do you have that?) If you're not using XP then delete it, or reinstall it on a separate partition.
Ensure you are running Unity 2D, and if it is still being slow try installing instead Xubuntu, Lubuntu (runs on LXDE) or Bodhi linux (runs on E17) - fastest is last, but all will give a significant speed improvement.
hayd
  • 2,397
