I am learning pentesting. I don't want to install BackTrack as my main OS. Instead, I'd like to install the relevant tools on my Ubuntu 12.04 system. My understanding is that it is possible to install this software on Ubuntu, but I don't know how. How can I do this?
Asked
Active
Viewed 1.0k times
Installing Backtrack software on Ubuntu is not recommended as it can confuse or break the package manager. However, if you want to do it, open terminal and do the following:
sudo bash
echo deb http://repo.offensive-security.com/dist/bt4 binary/ >> /etc/apt/sources.list
wget http://repo.offensive-security.com/dist/bt4/binary/public-key && sudo apt-key add public-key && sudo aptitude update
for i in $(cat backtrack.txt); do sudo apt-get -y install $i; done
Now, copy the following into Gedit and save it to your home directory as bt_menu_update.pl:
#!/usr/bin/perl
# Written by Mick Grove
# http://micksmix.wordpress.com
# [v0.1] 11/20/2009
# BSD Licensed
# Redistribution and use in source and binary forms, with or without
# modification, are permitted provided that the following conditions are
# met:
# * Redistributions of source code must retain the above copyright
# notice, this list of conditions and the following disclaimer.
# * Redistributions in binary form must reproduce the above
# copyright notice, this list of conditions and the following disclaimer
# in the documentation and/or other materials provided with the
# distribution.
# * Neither the name of the nor the names of its
# contributors may be used to endorse or promote products derived from
# this software without specific prior written permission.
# THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
# "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
# LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
# A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
# OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
# SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
# LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
# DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
# THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
# (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
# OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
use strict;
use warnings;
use Tie::File;
my $dir = "/usr/local/share/applications";
my $section = "Desktop Entry";
my $in_section;
my @files;
opendir(BIN, $dir) or die "Can't open $dir: $!";
while (defined(my $file = readdir BIN))
next if $file =~ /^\.\.?$/; # skip . and ..
if ($file =~ m/.*\.desktop$/i)
push(@files, $file);
closedir(BIN);
foreach my $curfile (@files)
open(FH, " chomp(my @fileparts = );
close(FH);
my $termval = TerminalStatus(\@fileparts);
next if $termval == 0; # skip if this is not a terminal application
#lets see if this is actually a BT program
my $btprogram = IsBTProgram(\@fileparts);
next if $btprogram == 0; # skip if this is not a BT application
my $ExecKey = "Exec";
my $TerminalKey = "Terminal";
my @tiedfile;
#open this file for editing
tie @tiedfile, 'Tie::File', "$dir/$curfile" or die "$!";
#read file line by line here
# updating "Exec" line
foreach my $fline (@tiedfile)
next if $fline =~ /^#/; # skip comments
next if $fline =~ /^\s*$/; # skip empty lines
if ($fline =~ /^\[$section\]$/)
$in_section = 1;
next;
if ($fline =~ /^\[/)
$in_section = 0;
next;
my $oldline;
my $updatedline;
if ($in_section and $fline =~ /^$ExecKey\s*=\s*(.*)$/)
# this means we have the "Exec key"
$oldline = $1;
next if $oldline =~ m/^.*xterm -e.*;bash.*$/i; #skip
$oldline =~ s/"/\\"/img;
$updatedline = "Exec=xterm -e \"$oldline;bash\"";
$fline = $updatedline;
print "New exec: " . $fline . "\n";
next;
elsif ($in_section and $fline =~ /^$TerminalKey\s*=\s*(.*)$/)
# this means we have the "Terminal key"
# we will set it to "0" to turn it off --- we are launching
# xterm ourselves, if we set to 1, we'll get an extra
# terminal opened
$oldline = $1;
$updatedline = "Terminal=0";
next;
untie @tiedfile;
print "\n\nAll menu entries have been updated\n";
### Subroutines ###
sub TerminalStatus
my @lines = @{$_[0]};
my $termkeyval = 0; #default = 0 FALSE, 1= TRUE
my $i = 0;
my $execkeyval = 0; #default = 0 = this exec line probably wasn't set by us
foreach my $fline (@lines)
$in_section = 1;
next;
$in_section = 0;
next;
# this means we have the "terminal key"
$termkeyval = $1;
next; #last;
# this means we have the "exec key"
$execkeyval = $1;
if ($execkeyval =~ m/^.*xterm -e.*;bash.*$/i)
$execkeyval = 1; # this script likely set this value before
next; #last;
if ($execkeyval eq 1)
# force this to true, because this can be updated by this script,
# b/c we appear to have modified this entry before.
$termkeyval = 1;
return $termkeyval;
<a name="IsBTProgram-"></a>sub IsBTProgram
my $key = "Categories";
my $isbtprog = 0; #default = FALSE = 0
my $i = 0;
foreach my $fline (@lines) {
if ($fline =~ /^\[$section\]$/) {
$in_section = 1;
next;
if ($fline =~ /^\[/) {
$in_section = 0;
next;
if ($in_section and $fline =~ /^$key\s*=\s*(.*)$/)
if ($1 =~ m/.*BT-.*/i)
$isbtprog = 1;
last;
return $isbtprog;
and in the terminal, run:
cd ~/
mkdir menu_backup
sudo cp /usr/local/share/applications/* ~/menu_backup
followed by perl ./bt_menu_update.pl. Log out and log back in, and enjoy.
Source: http://micksmix.wordpress.com/2009/10/28/install-backtrack-4-tools-in-ubuntu/
nanofarad
- 20,906
