I'm wondering if it's possible to hide a folder without renaming it with a dot on the Desktop.
Ubuntu 12.04
Thanks
Matt
  • 61
You can create a file called .hidden and write the names of the files you want to hide in it.
BEFORE
  • /home/user/Desktop/file1
  • /home/user/Desktop/file2
CREATE .hidden file, echo file1 > /home/user/Desktop/.hidden
AFTER
  • /home/user/Desktop/file1 (HIDDEN)
  • /home/user/Desktop/.hidden (HIDDEN)
No file got moved nor renamed.
user55822
  • 3,245
Yes, it is possible. But the problem is that then you won't be able to see any icon on your desktop, but will be able to see everything in /home/user/Desktop.
The trick is fairly simple and straightforward:
  • Install gnome-tweak-tool:
    sudo apt-get install gnome-tweak-tool
  • Run gnome-tweak-tool and click on Desktop option. Turn "Have file manager handle the desktop" to off.
    gnome-tweak-tool disabling icons
And you're good to go!
pomsky
  • 70,557
green
  • 14,406
