I have installed 12.04 alongside Windows 7. Now I am happy with 12.04 that it works better for me. I really want to remove Windows 7 from my HDD and left 12.04 to work with me, and got free HDD space back to 12.04.
Is there an easy way to remove Windows 7 out and keep 12.04 without problem?
Peachy
  • 7,235
  • 40
  • 47
I would do the following to remove said partition:
  1. Boot a live CD.
  2. Select "Try Ubuntu"
  3. Open Gparted(Search for it)
  4. Make sure your hard disk is selected in the dropdown in the upper right.
  5. Right-click the Windows partition and format it to NTFS.
  6. Right click your old Windows partition and click Resize/Move. Resize it to an arbitrarily-small size, at least 64MB.
  7. Right-click your Ubuntu partition and click Resize/Move
  8. Drag the arrows on the left or right as far as possible to make the partition bigger.
  9. Click Resize to accept the dialog.
  10. Click apply in the toolbar above. The icon is a green check.
  11. Acknowledge the warning. Allow the operation to complete, and then open a terminal.
  12. Type: mkdir /mnt/sda2 && sudo mount -t ext4 /dev/sda2 /bin/bash, assuming sda2 is our Ubuntu partition.
  13. Run sudo grub-install /dev/sda and then sudo update-grub.
Please note that if Ubuntu is in an extended partition, you should right-click and resize the extended partition first.
nanofarad
  • 20,906
Of course. Just format the drive in which Windows was installed and run the following command - sudo update-grub
You're done. :D
