Possible Duplicate:
What is the easiest way to resolve apt-get BADSIG GPG errors?
Of late, I've been getting this long list of errors every time I run apt-get update from the terminal. These errors weren't there before, I have no clue how they cropped up all of a sudden. I even tried some methods as suggested in some forums, but they apparently haven't worked for me so far. I've even tried changing the server, but to no avail. I'd be really glad to receive help on this issue.
The errors are here: http://paste.ubuntu.com/544093/
Type the following in your terminal one by one,
sudo apt-key adv --keyserver keyserver.ubuntu.com --recv-keys 2E206FF0
sudo apt-key adv --keyserver keyserver.ubuntu.com --recv-keys 17CF995E
sudo apt-key adv --keyserver keyserver.ubuntu.com --recv-keys 298C1C9F
sudo apt-key adv --keyserver keyserver.ubuntu.com --recv-keys E21DD54D
sudo apt-key adv --keyserver keyserver.ubuntu.com --recv-keys 5139BD61
sudo apt-key adv --keyserver keyserver.ubuntu.com --recv-keys 9E5DB0C8
sudo apt-key adv --keyserver keyserver.ubuntu.com --recv-keys 4631BBEA
sudo apt-key adv --keyserver keyserver.ubuntu.com --recv-keys 0624A220
Note:
  • After running all the above commands you may get few errors, because i have found lot of errors in your result,post the complete output of sudo apt-get update after running all those commands.So that i may help you.
karthick87
  • 84,513
Is there a transparent proxy between you and the Ubuntu archive? It seems that several of the Packages files are not being fetched correctly (which results in the GPG failures). Try this from the command line:
curl -I http://extras.ubuntu.com/ubuntu/dists/maverick/Release
Does that show something like this? (The first line showing "200 OK" would be expected if things aren't totally broken.)
HTTP/1.1 200 OK
Date: Thu, 23 Dec 2010 21:08:06 GMT
Server: Apache/2.2.8 (Ubuntu)
Last-Modified: Sun, 10 Oct 2010 23:00:00 GMT
ETag: "f72018-dfca-4924b34083c00"
Accept-Ranges: bytes
Content-Length: 57290
Content-Type: text/plain
If this looks clean, try it again:
sudo apt-get clean
sudo apt-get update
Kees Cook
  • 17,823
Run the following in terminal,
sudo apt-key adv --keyserver pgp.mit.edu --recv-keys 5044912E
sudo apt-get install ubuntu-extras-keyring
sudo apt-get update
Note:
  • If you get any errors after running the above commands,post the output here.
karthick87
  • 84,513
sudo add-apt-repository ppa:nilarimogard/webupd8
sudo apt-get update
sudo apt-get install launchpad-getkeys
sudo launchpad-getkeys
Keep me informed
Ilias
  • 1,326
