-2
I am trying to install Cinnamon and allow myself to choose which one I would prefer. I have done the first two main steps.
sudo add-apt-repository ppa:merlwiz79/cinnamon-ppa
and
sudo apt-get update
which were both successful and then I try to run.
sudo apt-get install cinnamon
and this is what I get -
Reading package lists... Done
Building dependency tree
 cinnamon : Depends: gir1.2-muffin-3.0 but it is not going to be installed
            Depends: libcogl5 (>= 1.7.4) but it is not installable
            Depends: libmuffin0 (>= 1.0.0-0ubuntu1~precise) but it is not going to be installed
            Recommends: gnome-themes-standard but it is not going to be installed
            Recommends: gnome-session-fallback but it is not going to be installed
Any help would be appreciated!
Mitch
  • 109,787
I would try removing the PPA you are trying to use and use the Cinnamon's official PPA for Ubuntu.
https://launchpad.net/~gwendal-lebihan-dev/+archive/cinnamon-stable
I got the above link to the ppa by visiting Cinnamon's Download Page
I would assume that the unofficial PPA you are trying to use is having some problems.
I had Cinnamon installed from the official PPA so I know that it was working as of April or May...
to use the official PPA(instructions from the PPA's Download page)
sudo add-apt-repository  ppa:gwendal-lebihan-dev/cinnamon-stable
sudo apt-get update
If you want to try to use the unoffical PPA you were trying to use you can try to fix the broken packages via sudo apt-get install -f
To remove the old PPA via the command line run the following:
sudo add-apt-repository --remove  ppa:merlwiz79/cinnamon-ppa
It will promt you just like it did when you added it, press Enter to remove.
You can also remove it via the Software Sources in the edit menu of the Software Center or the Setting button of the Update Manager if you want to do it with a GUI.
Just click on the Other Software tab on the Software Sources window and highlight the PPA(the name is at the end of the line) and then click the Remove button.
After using any of the above methods you will need to run sudo apt-get update again to complete the removal
TrailRider
  • 7,157
