39
I have enable FullScreenmode in Dosbox under Ubuntu 12.04 . But still i am not getting it in Fullscreen. My turbo c++ windows is less than my screen size.
Jorge Castro
  • 73,717
BigSack
  • 2,713
8 Answers8
48
First, press ctrl + F10 to lock mouse to dosbox and then try alt + Enter.
gsedej
  • 5,024
19
You need to edit dosbox-0.74.conf as given below
Go to terminal and type gedit /home/<USER_NAME>/.dosbox/dosbox-0.74.conf
and make these changes:
fullscreen=true
fulldouble=true
fullresolution=1366x768
windowresolution=1366x768
output=opengl  #**MOST IMPORTANT**
autolock=true
Now save the file and open dosbox. It should be fullscreen with full workspace.
NOTE : Original source of this answer : Click Here
Pascal
  • 273
Severus Tux
  • 10,126
  • Goto /home/user/dosbox.conf
  • Find resolution
  • Change fullresolution from original to your choice (eg. fullresolution=640x480)
  • Leave windowresolution intact (i.e, windowresolution=original) as you might want a smaller sized window.
Optional: change fullscreen to true (i.e, fullscreen=true) if you want to start dosbox in fullscreen mode
Anurag R
  • 111
I think the Alt-Enter command makes DOSBox go full-screen. That might not be your problem, though.
fullresolution=auto
windowresolution=auto
for me auto setting on these two functions, works better.
Ctrl+F10 is for accessing mouse
Alt+Enter is to switch from full screen to small.
George Udosen
  • 37,534
Severus Tux solution worked on my raspberry pi, but took up far too much computing power. Extreme lag and overheating followed from just rendering the dos prompt.
Another solution is to change the "scaler" parameter to a size that fits your screen the best. you can either double, or tripple the number of pixels used:
scaler=normal2x forced
or
scaler=normal3x forced
pick the one that fits your fullscreen mode the best.
Inside the Dosbox conf files inside ScummVM files, it uses:
output=overlay
(Also a youtuber recommended)
fullresolution=0x0x
Also for RetroPie DosBox, it had the settings here:
~/.dosbox/dosbox-SVN.conf
phyatt
  • 311
First, let's mention that all configuration info is available here https://www.dosbox.com/wiki/Dosbox.conf
Regarding your question:
1. Where is the config file on Linux ?
For Linux the configfile is created on the first run in ~/.dosbox/ The name is dosbox-{version}.conf where version is currently 0.74
-> Your config file is here: /home/<USER_NAME>/.dosbox/dosbox-0.74.conf
2. What are the full-screen related settings in this config file ?
fullscreen = true | false
fulldouble = true | flase
-> edit /home/<USER_NAME>/.dosbox/dosbox-0.74.conf
and set:
fullscreen = true
fulldouble = true
3. Bonus
Changing full-screen mode at runtime (as per this answer )
Ctrl+F10 to lock/unlock mouse in DOSBOX window (if needed)
Alt+Enter to toggle DOSBOX's full-screen mode
Pascal
  • 273
