37
When I am running some software using sudo command it showing error like
cannot connect to X server
For example if I run the following command:
$ sudo gedit /etc/profile
I am getting following command
(gedit:6758): WARNING **: Command line `dbus-launch --autolaunch=84b871d735f31ffe014dc9ba00000009 --binary-syntax --close-stderr'
exited with non-zero exit status 1:
Autolaunch error: X11 initialization failed.
Cannot open display:
Run 'gedit --help' to see a full list of available command line options.
Or if I am running super-boot-manager I am getting following error
buc: cannot connect to X server
Please help.
Peachy
  • 7,235
  • 40
  • 47
Apurba
  • 1,438
You need to allow the root user access to the X server:
xhost local:root
And point the command to the right DISPLAY:
sudo DISPLAY=$DISPLAY gedit /etc/profile
Thor
  • 3,678
20
Finally the problem is solved. I have just added the line:
Defaults env_keep="DISPLAY XAUTHORITY"
at the end of visudo.
To do that you have to run:
sudo visudo
it will open the file then add the above line at the end.
Thanks to all, specially @Thor for kind help
Apurba
  • 1,438
Supplementing @Thor's answer, run:
xhost local:root
before sudo gedit. To make this permanent, add the line
xhost local:root
to the ~/.xinitrc 1 file. Create the file if it doesn't exist.
1 https://askubuntu.com/a/720120/452398
adabru
  • 240
set DISPLAY and XAUTHORITY variable environment before running your scrip. for example in systemctl service file:
[Unit]
Description=Start Clock
[Service] Environment=DISPLAY=:0 Environment=XAUTHORITY=/home/pi/.Xauthority ExecStart=/usr/bin/python3 /home/pi/clock.py Restart=always RestartSec=10s KillMode=process TimeoutSec=infinity
[Install] WantedBy=graphical.target
Hamid
  • 101
