While trying to compile a program with the following command:
g++ -o <output_file> <my_file.cpp>
I found the following report....
The program 'g++' can be found in the following packages:
 * g++
 * pentium-builder
 Try: sudo apt-get install <selected package>
Then I tried...
nawshad@ubuntu:~/Thesis/Codes/Thesis_Utility_Function/Test Codes$ sudo apt-get   install   g++
Reading package lists... Done
Building dependency tree
You might want to run 'apt-get -f install' to correct these:
 g++ : Depends: g++-4.6 (>= 4.6.3-1~) but it is not going to be installed
 libqt4-opengl : Depends: libqtcore4 (= 4:4.8.1-0ubuntu4.1) but 4:4.8.1-0ubuntu4 is to be installed
                 Depends: libqtgui4 (= 4:4.8.1-0ubuntu4.1) but 4:4.8.1-0ubuntu4 is to be installed
 libqt4-svg : Depends: libqtcore4 (= 4:4.8.1-0ubuntu4.1) but 4:4.8.1-0ubuntu4 is to be installed
E: Unmet dependencies. Try 'apt-get -f install' with no packages (or specify a solution).
I can't install due to unmet dependencies.
While updating, the following error occurs:
nawshad@ubuntu:~$ sudo apt-get update
[sudo] password for nawshad:
E: Could not get lock /var/lib/apt/lists/lock - open (11: Resource temporarily unavailable)
E: Unable to lock directory /var/lib/apt/lists/
E: Could not get lock /var/lib/dpkg/lock - open (11: Resource temporarily unavailable)
E: Unable to lock the administration directory (/var/lib/dpkg/), is another process using it?
I followed the instructions at Unable to lock the administration directory (/var/lib/dpkg/) is another process using it?), but the unmet dependencies are still not resolved.
