I want to install dpkg-reconfigure in Ubuntu 12.04 LTS install on Amazon EC2? How to go about it?
dpkg-reconfigure is provided by the debconf package, which should always be installed in any Ubuntu 12.04 install. If it's not, use:
sudo apt-get install debconf
In your case, you are running Amazon's AMI Linux which is based on CentOS, not Ubuntu. That's why apt-get or dpkg-reconfgure, which are native to Debian/Ubuntu, are not available on your EC2 instance.
ish
  • 141,990
If debconf is installed, it's located in /usr/sbin what might not be in your PATH variable.
Suuuehgi
  • 219
Normally it's already installed in Ubuntu. But if you are using some customized version without dpkg, you should be able to install using the command
sudo apt-get install dpkg
On a fresh Kubuntu 12.10 install, you will need to install these additional packages:
  • ia32libs (ΒΌ GiB!)
  • libc6-i386
  • lib32asound2
  • lib32z1
  • nspluginwrapper
If you forget one, and try to install the Receiver deb package, the package system will end up in sort of a limbo. In that case (only!), run:
$ sudo dpkg -r icaclient
To remove the half-installed Receiver and start over.
After installing the 64-but Citrix Receiver 12.1 (or any NPAPI plugin for that matter), you need to reconfigure nspluginwrapper:
$ sudo dpkg-reconfigure nspluginwrapper
This triggers the nspluginwrapper installer to look for new NPAPI plugins and link them into the various installed browsers in the correct manner.
