93
How do you configure proxy settings in the Ubuntu Server or Minimal (CLI) versions using the terminal?
Braiam
  • 69,112
Asad
  • 931
System-wide proxies in CLI Ubuntu/Server must be set as environment variables.
  • Open the /etc/environment file with vi (or your favorite editor). This file stores the system-wide variables initialized upon boot.
  • Add the following lines, modifying appropriately. You must duplicate in both upper-case and lower-case because (unfortunately) some programs only look for one or the other:
    http_proxy="http://myproxy.server.com:8080/"
    https_proxy="http://myproxy.server.com:8080/"
    ftp_proxy="http://myproxy.server.com:8080/"
    no_proxy="localhost,127.0.0.1,localaddress,.localdomain.com"
    HTTP_PROXY="http://myproxy.server.com:8080/"
    HTTPS_PROXY="http://myproxy.server.com:8080/"
    FTP_PROXY="http://myproxy.server.com:8080/"
    NO_PROXY="localhost,127.0.0.1,localaddress,.localdomain.com"
  • apt-get, aptitude, etc. will not obey the environment variables when used normally with sudo. So separately configure them; create a file called 95proxies in /etc/apt/apt.conf.d/, and include the following:
    Acquire::http::proxy "http://myproxy.server.com:8080/";
    Acquire::ftp::proxy "ftp://myproxy.server.com:8080/";
    Acquire::https::proxy "https://myproxy.server.com:8080/";
Finally, logout and reboot to make sure the changes take effect.
Sources: 1, 2. See 1 in particular for additional help, including a script to quickly turn on/off the proxies.
ish
  • 141,990
10
If you have an authenticating proxy, then the URLs will be different. Instead of:
You'll have:
"http://user_name:password@myproxy.server.com:8080/"
Note that these are still URLs, so passwords (and possibly usernames) will have to be URL encoded.
For example, a username of muru and a password of )qv3TB3LBm7EkP} would look like:
"http://muru:)qv3TB3LBm7EkP%7D@myproxy.server.com:8080/"
This can be done in various ways:
  1. There several websites for encoding:
  2. Programmatic:
In a pinch, you can use man url to see which characters need to be encoded:
An escaped octet is encoded as a character triplet,
consisting of the percent character "%" followed by
the two hexadecimal digits representing the octet code...
And the octet codes are available on man ascii.
muru
  • 207,228
                                 Proxy Environment Variables:
http_proxy: Proxy server for HTTP Traffic
https_proxy: Proxy server for HTTPS traffic
ftp_proxy: Proxy server for FTP traffic
no_proxy: Patterns for IP addresses or domain names that shouldn’t use the proxy
The value for every proxy setting, except for no_proxy, uses the same template. proxy_http=username:password@proxy-host:port
Temporary setting proxy: export HTTP_PROXY=user:pass@my.proxy.server:8080
Persistent Proxy Settings: use vim ~/.bash_profile to open bash setup file, then put following lines inside it
export http_proxy=username:password@proxyhost.com:8080
export https_proxy=username:password@proxyhost.com:8081
export no_proxy=localhost, 127.0.0.1, *.my.lan
use source ~/.bash_profile to apply the changes
