I bought new Toshiba satellite C870-10L and just installed Ubuntu 12.04. However, I can't find any wireless connection. I have following hardware for networking:
Integrated Ethernet 10/100 Ethernet
Wireless Integrated wireless 802.11bgn
This is what I have tried so far in terminal (commands and output given below):
lspci -vvv
00:00.0 Host bridge: Intel Corporation 2nd Generation Core Processor Family DRAM Controller (rev 09) Subsystem: Toshiba America Info Systems Device fb41 Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx- Status: Cap+ 66MHz- UDF- FastB2B+ ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort+ >SERR- <PERR- INTx- Latency: 0 Capabilities: <access denied> 00:01.0 PCI bridge: Intel Corporation Xeon E3-1200/2nd Generation Core Processor Family PCI Express Root Port (rev 09) (prog-if 00 [Normal decode]) Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx+ Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx- Latency: 0, Cache Line Size: 64 bytes Bus: primary=00, secondary=01, subordinate=06, sec-latency=0 I/O behind bridge: 00004000-00004fff Memory behind bridge: c2000000-c2ffffff Prefetchable memory behind bridge: 00000000b0000000-00000000bfffffff Secondary status: 66MHz- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- <SERR- <PERR- BridgeCtl: Parity- SERR- NoISA- VGA+ MAbort- >Reset- FastB2B- PriDiscTmr- SecDiscTmr- DiscTmrStat- DiscTmrSERREn- Capabilities: <access denied> Kernel driver in use: pcieport Kernel modules: shpchp 00:14.0 USB controller: Intel Corporation Panther Point USB xHCI Host Controller (rev 04) (prog-if 30 [XHCI]) Subsystem: Toshiba America Info Systems Device fb41 Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx+ Status: Cap+ 66MHz- UDF- FastB2B+ ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx- Latency: 0 Interrupt: pin A routed to IRQ 42 Region 0: Memory at c3100000 (64-bit, non-prefetchable) [size=64K] Capabilities: <access denied> Kernel driver in use: xhci_hcd 00:16.0 Communication controller: Intel Corporation Panther Point MEI Controller #1 (rev 04) Subsystem: Toshiba America Info Systems Device fb41 Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx+ Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx- Latency: 0 Interrupt: pin A routed to IRQ 44 Region 0: Memory at c3114000 (64-bit, non-prefetchable) [size=16] Capabilities: <access denied> Kernel driver in use: mei Kernel modules: mei 00:1a.0 USB controller: Intel Corporation Panther Point USB Enhanced Host Controller #2 (rev 04) (prog-if 20 [EHCI]) Subsystem: Toshiba America Info Systems Device fb41 Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx- Status: Cap+ 66MHz- UDF- FastB2B+ ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx- Latency: 0 Interrupt: pin A routed to IRQ 16 Region 0: Memory at c3119000 (32-bit, non-prefetchable) [size=1K] Capabilities: <access denied> Kernel driver in use: ehci_hcd 00:1b.0 Audio device: Intel Corporation Panther Point High Definition Audio Controller (rev 04) Subsystem: Toshiba America Info Systems Device fb41 Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx+ Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx- Latency: 0, Cache Line Size: 64 bytes Interrupt: pin A routed to IRQ 47 Region 0: Memory at c3110000 (64-bit, non-prefetchable) [size=16K] Capabilities: <access denied> Kernel driver in use: snd_hda_intel Kernel modules: snd-hda-intel 00:1c.0 PCI bridge: Intel Corporation Panther Point PCI Express Root Port 1 (rev c4) (prog-if 00 [Normal decode]) Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx- Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx- Latency: 0, Cache Line Size: 64 bytes Bus: primary=00, secondary=07, subordinate=07, sec-latency=0 I/O behind bridge: 0000f000-00000fff Memory behind bridge: fff00000-000fffff Prefetchable memory behind bridge: 00000000fff00000-00000000000fffff Secondary status: 66MHz- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort+ <SERR- <PERR- BridgeCtl: Parity- SERR- NoISA- VGA- MAbort- >Reset- FastB2B- PriDiscTmr- SecDiscTmr- DiscTmrStat- DiscTmrSERREn- Capabilities: <access denied> Kernel driver in use: pcieport Kernel modules: shpchp 00:1c.1 PCI bridge: Intel Corporation Panther Point PCI Express Root Port 2 (rev c4) (prog-if 00 [Normal decode]) Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx- Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx- Latency: 0, Cache Line Size: 64 bytes Bus: primary=00, secondary=08, subordinate=08, sec-latency=0 I/O behind bridge: 00003000-00003fff Memory behind bridge: c3000000-c30fffff Prefetchable memory behind bridge: 00000000fff00000-00000000000fffff Secondary status: 66MHz- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- <SERR- <PERR- BridgeCtl: Parity- SERR- NoISA- VGA- MAbort- >Reset- FastB2B- PriDiscTmr- SecDiscTmr- DiscTmrStat- DiscTmrSERREn- Capabilities: <access denied> Kernel driver in use: pcieport Kernel modules: shpchp 00:1c.2 PCI bridge: Intel Corporation Panther Point PCI Express Root Port 3 (rev c4) (prog-if 00 [Normal decode]) Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx- Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx- Latency: 0, Cache Line Size: 64 bytes Bus: primary=00, secondary=09, subordinate=0e, sec-latency=0 I/O behind bridge: 00002000-00002fff Memory behind bridge: c1000000-c1ffffff Prefetchable memory behind bridge: 00000000c0000000-00000000c0ffffff Secondary status: 66MHz- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- <SERR- <PERR- BridgeCtl: Parity- SERR- NoISA- VGA- MAbort- >Reset- FastB2B- PriDiscTmr- SecDiscTmr- DiscTmrStat- DiscTmrSERREn- Capabilities: <access denied> Kernel driver in use: pcieport Kernel modules: shpchp 00:1d.0 USB controller: Intel Corporation Panther Point USB Enhanced Host Controller #1 (rev 04) (prog-if 20 [EHCI]) Subsystem: Toshiba America Info Systems Device fb41 Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx- Status: Cap+ 66MHz- UDF- FastB2B+ ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx- Latency: 0 Interrupt: pin A routed to IRQ 23 Region 0: Memory at c3118000 (32-bit, non-prefetchable) [size=1K] Capabilities: <access denied> Kernel driver in use: ehci_hcd 00:1f.0 ISA bridge: Intel Corporation Panther Point LPC Controller (rev 04) Subsystem: Toshiba America Info Systems Device fb41 Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx- Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx- Latency: 0 Capabilities: <access denied> Kernel modules: iTCO_wdt 00:1f.2 SATA controller: Intel Corporation Panther Point 6 port SATA Controller [AHCI mode] (rev 04) (prog-if 01 [AHCI 1.0]) Subsystem: Toshiba America Info Systems Device fb41 Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx+ Status: Cap+ 66MHz+ UDF- FastB2B+ ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx- Latency: 0 Interrupt: pin B routed to IRQ 41 Region 0: I/O ports at 5048 [size=8] Region 1: I/O ports at 5054 [size=4] Region 2: I/O ports at 5040 [size=8] Region 3: I/O ports at 5050 [size=4] Region 4: I/O ports at 5020 [size=32] Region 5: Memory at c3117000 (32-bit, non-prefetchable) [size=2K] Capabilities: <access denied> Kernel driver in use: ahci 00:1f.3 SMBus: Intel Corporation Panther Point SMBus Controller (rev 04) Subsystem: Toshiba America Info Systems Device fb41 Control: I/O+ Mem+ BusMaster- SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx- Status: Cap- 66MHz- UDF- FastB2B+ ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx- Interrupt: pin C routed to IRQ 10 Region 0: Memory at c3115000 (64-bit, non-prefetchable) [size=256] Region 4: I/O ports at 5000 [size=32] Kernel modules: i2c-i801 01:00.0 VGA compatible controller: Advanced Micro Devices [AMD] nee ATI Whistler LE [AMD Radeon HD 6625M Graphics] (prog-if 00 [VGA controller]) Subsystem: Toshiba America Info Systems Device fb41 Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx+ Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx- Latency: 0, Cache Line Size: 64 bytes Interrupt: pin A routed to IRQ 45 Region 0: Memory at b0000000 (64-bit, prefetchable) [size=256M] Region 2: Memory at c2000000 (64-bit, non-prefetchable) [size=128K] Region 4: I/O ports at 4000 [size=256] Expansion ROM at c2040000 [disabled] [size=128K] Capabilities: <access denied> Kernel driver in use: radeon Kernel modules: radeon 01:00.1 Audio device: Advanced Micro Devices [AMD] nee ATI Turks HDMI Audio [Radeon HD 6000 Series] Subsystem: Toshiba America Info Systems Device fb41 Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx+ Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx- Latency: 0, Cache Line Size: 64 bytes Interrupt: pin B routed to IRQ 46 Region 0: Memory at c2020000 (64-bit, non-prefetchable) [size=16K] Capabilities: <access denied> Kernel driver in use: snd_hda_intel Kernel modules: snd-hda-intel 08:00.0 Network controller: Realtek Semiconductor Co., Ltd. Device 8723 Subsystem: Realtek Semiconductor Co., Ltd. Device 0723 Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx- Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx- Latency: 0, Cache Line Size: 64 bytes Interrupt: pin A routed to IRQ 10 Region 0: I/O ports at 3000 [size=256] Region 2: Memory at c3000000 (64-bit, non-prefetchable) [size=16K] Capabilities: <access denied> 09:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8101E/RTL8102E PCI Express Fast Ethernet controller (rev 05) Subsystem: Toshiba America Info Systems Device fb37 Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx+ Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx- Latency: 0, Cache Line Size: 64 bytes Interrupt: pin A routed to IRQ 43 Region 0: I/O ports at 2000 [size=256] Region 2: Memory at c0004000 (64-bit, prefetchable) [size=4K] Region 4: Memory at c0000000 (64-bit, prefetchable) [size=16K] Capabilities: <access denied> Kernel driver in use: r8169 Kernel modules: r8169lsmod
Module Size Used by ums_realtek 17920 0 uas 17828 0 usb_storage 39646 1 ums_realtek snd_hda_codec_hdmi 31775 1 sparse_keymap 13658 0 bnep 17830 2 rfcomm 38139 0 bluetooth 158438 10 bnep,rfcomm parport_pc 32114 0 ppdev 12849 0 snd_hda_codec_realtek 174222 1 snd_hda_intel 32765 5 snd_hda_codec 109562 3 snd_hda_codec_hdmi,snd_hda_codec_realtek,snd_hda_intel snd_hwdep 13276 1 snd_hda_codec snd_pcm 80845 3 snd_hda_codec_hdmi,snd_hda_intel,snd_hda_codec psmouse 72919 0 serio_raw 13027 0 snd_seq_midi 13132 0 snd_rawmidi 25424 1 snd_seq_midi snd_seq_midi_event 14475 1 snd_seq_midi snd_seq 51567 2 snd_seq_midi,snd_seq_midi_event joydev 17393 0 uvcvideo 67203 0 snd_timer 28931 2 snd_pcm,snd_seq radeon 737789 4 videodev 86588 1 uvcvideo snd_seq_device 14172 3 snd_seq_midi,snd_rawmidi,snd_seq video 19068 0 ttm 65344 1 radeon drm_kms_helper 45466 1 radeon drm 197692 6 radeon,ttm,drm_kms_helper toshiba_bluetooth 12711 0 wmi 18744 0 snd 62064 20 snd_hda_codec_hdmi,snd_hda_codec_realtek,snd_hda_intel,snd_hda_codec,snd_hwdep,snd_pcm,snd_rawmidi,snd_seq,snd_timer,snd_seq_device mac_hid 13077 0 i2c_algo_bit 13199 1 radeon soundcore 14635 1 snd snd_page_alloc 14108 2 snd_hda_intel,snd_pcm mei 36570 0 lp 17455 0 parport 40930 3 parport_pc,ppdev,lp usbhid 41906 0 r8169 56321 0 hid 77367 1 usbhidifconfig -a
eth0 Link encap:Ethernet HWaddr 4c:72:b9:1a:2f:e7 inet addr:192.168.1.5 Bcast:192.168.1.255 Mask:255.255.255.0 inet6 addr: fe80::4e72:b9ff:fe1a:2fe7/64 Scope:Link UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1 RX packets:584588 errors:0 dropped:0 overruns:0 frame:0 TX packets:335858 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:1000 RX bytes:801442328 (801.4 MB) TX bytes:24323663 (24.3 MB) Interrupt:43 Base address:0xe000 lo Link encap:Local Loopback inet addr:127.0.0.1 Mask:255.0.0.0 inet6 addr: ::1/128 Scope:Host UP LOOPBACK RUNNING MTU:16436 Metric:1 RX packets:991 errors:0 dropped:0 overruns:0 frame:0 TX packets:991 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:0 RX bytes:119419 (119.4 KB) TX bytes:119419 (119.4 KB)iwconfig
lo no wireless extensions. eth0 no wireless extensions.sudo lshw -class network
[sudo] password for tryggvi: *-network UNCLAIMED description: Network controller product: Realtek Semiconductor Co., Ltd. vendor: Realtek Semiconductor Co., Ltd. physical id: 0 bus info: pci@0000:08:00.0 version: 00 width: 64 bits clock: 33MHz capabilities: pm msi pciexpress bus_master cap_list configuration: latency=0 resources: ioport:3000(size=256) memory:c3000000-c3003fff *-network description: Ethernet interface product: RTL8101E/RTL8102E PCI Express Fast Ethernet controller vendor: Realtek Semiconductor Co., Ltd. physical id: 0 bus info: pci@0000:09:00.0 logical name: eth0 version: 05 serial: 4c:72:b9:1a:2f:e7 size: 100Mbit/s capacity: 100Mbit/s width: 64 bits clock: 33MHz capabilities: pm msi pciexpress msix vpd bus_master cap_list ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd autonegotiation configuration: autonegotiation=on broadcast=yes driver=r8169 driverversion=2.3LK-NAPI duplex=full firmware=rtl_nic/rtl8105e-1.fw ip=192.168.1.5 latency=0 link=yes multicast=yes port=MII speed=100Mbit/s resources: irq:43 ioport:2000(size=256) memory:c0004000-c0004fff memory:c0000000-c0003fffrfkill list all
