How can I find out owner and group of a directory in Ubuntu?
You can do this: 1st way:
ls -l /path/to/file
*the third field in the ls -l output is the user and the fourth is the group
2nd way:
stat /path/to/file
$ stat py
File: `py'
Size: 32 Blocks: 8 IO Block: 4096 regular file
Device: 801h/2049d Inode: 429064 Links: 1
Access: (0777/-rwxrwxrwx) Uid: ( 1000/ razvan) Gid: ( 1000/ razvan)
Access: 2012-07-27 17:49:05.682143441 +0300
Modify: 2012-07-01 03:58:02.848540175 +0300
Change: 2012-08-01 21:12:57.129819212 +0300
The razvan in the Uid field is the owner/user, the razvan in the Gid field is the group. 8-|
3rd way: Get only the user and group with stat:
stat -c "%U %G" /path/to/file
- 3,756
Run ls with the -l flag to show the owner and group-owner of files and directories in the current directory (or in a specific named directory).
~$ ls -l
drwxr-xr-x 2 owner group 4096 Aug 12 19:12 Desktop
~$ ls -l /home/username
Run ls with the -l and -d flags to show this information about the current directory itself (or about a specific named directory):
~$ ls -ld
drwxr-xr-x 2 owner group 4096 Aug 12 19:12 .
~$ ls -ld ~/Desktop
- 119,640
- 5,275
To get the owner and group of a directory you need
ls -ld /path/to/folder
Otherwise you get the attributes of the contents of the directory.
- 2,897
In Nautilus (the GUI file manager)
Find the folder corresponding to the directory
Right click it.
Select Properties
Select the Permissions Tab
Providing you have the permission to change the permissions you can change them from that window, too.
- 13,436
My subtle way
ls -alF /path/to/folder | grep -Ei ' ./'
sample output
drwxr-xr-x 2 some-user some-group 4096 Feb 28 02:29 ./
- 2,378
