25
In default Home directory, there is a folder called Public. What purpose does that serve?
Are documents in that folder accessible to all users on the same computer?
What are the default permissions on that folder?
deshmukh
  • 4,121
The folder is used for sharing files publicly, so your files won't be exposed.
This folder isn’t shared by default, but you can easily set up several different types of file-sharing to easily share files on your local network.
This folder was originally meant for the Personal File Sharing tool, which is no longer included with Ubuntu by default. You can install the Personal File Sharing tool or use Ubuntu’s built-in file-sharing feature to share files.
The Personal File Sharing tool – also known as gnome-user-share – was the original reason for the Public folder. It uses Apache to offer convenient WebDAV-based file sharing, but doesn’t work with Windows systems. It supports Bluetooth file sharing, too.1
1Source:How-To Geek
Mitch
  • 109,787
