I have a system where all the partitions (/, /home, and swap) are encrypted except for /boot. /boot resides in an external device which also contains a set of encrypted key files used to automatically decrypt all of the partitions. In other words, my desired end result was to have 2-factor authentication using an external device and a password where the password would be entered once during boot and the boot scripts would use the password to decrypt all of the partitions.
I'm a newbie to Ubuntu (and Linux in general), but I did some trial and error modifying the various scripts found in initrd.img using update-initramfs. The cryptroot script seemed to be doing all the work mounting the partitions at first, but after some experimenting, it appears that it is only responsible for decrypting the root file system. I had modified a string in the script changing Enter the passphrase to simply Password, which appeared to work when decrypting the root file system, but used the old prompt again for decrypting the next partition. In other words, this is what I'm getting:
  1. cryptroot script loads.
  2. The script asks for a password to decrypt the key partition and mounts it.
  3. The script calls the setup_mapping function to decrypt the root file system.
  4. The script tries to read the key file from the key partition to decrypt the root file system.
  5. The root file system is decrypted and mounted.
  6. The system prompts to enter a passphrase to decrypt the next partition…
I think Ubuntu might be running another copy of the cryptroot script somewhere to decrypt all the other partitions after root, but I don't know what else to modify.
Kevin Li
  • 319
waltinator's answer gives a good start - finding out where the script resides on your filesystem. use whatever file searching tool you have available, and find the script in question. for instance, with fd, you can search the (usual candidates?) /etc and /usr:
fd cryptroot /etc
fd cryptroot /usr
Then, modify one or all of those scripts - not sure how to figure out reliably which one is used, i was only intested in the one under /usr/share/initramfs-tools/scripts/localtop, since my logs told me there was a problem there.
Finally, update / regenerate the initram filesystems, on ubuntu 22.04 with
sudo update-initramfs -c -k all
I only inserted some echo statements for debugging purposes; yet already during the call to update-initramfs those echo statements were run and I could see their output! this might be a way of testing whether the script you modified gets included, or not.
First, find out where cryptroot is, what package provides cryptroot, and what else (source, documentation, examples, ...) is in the package. Thusly:
walt@squid:~(0)$ locate cryptroot
/usr/share/initramfs-tools/hooks/cryptroot
/usr/share/initramfs-tools/scripts/local-top/cryptroot
walt@squid:~(0)$ dpkg -S !$
dpkg -S cryptroot
cryptsetup: /usr/share/initramfs-tools/hooks/cryptroot
cryptsetup: /usr/share/initramfs-tools/scripts/local-top/cryptroot
walt@squid:~(0)$ dpkg -L cryptsetup
waltinator
  • 37,856
