I have tried to create a .desktop file to run vncviewer (tight vnc connecting to a mac). I have entered below into the file.
[Desktop Entry]
Version=x.y
Name=VNCViewer
Comment=This is my comment
Exec=/usr/bin/vncviewer 10.0.1.5:5900
Terminal=true
When I double click the file it returns "There was an error launching the application."
Any suggestions what I have done wrong in my .desktop file?
Jorge Castro
  • 73,717
Mikael
  • 141
Ok I found what the problem was.
You are missing one entry in the file. Place the following entry into the file
Type=Application
After you save the file, you'll notice it's icon change to look more like an application than what is looks like now (a text/script file).
Even if you make the file executable Ubuntu Desktop doesn't know if this file is a script or application and assumes it's a script. But if you place the Type=Application it will run it fine.
Maybe you can give this a try: Exec=bash -c "/usr/bin/vncviewer 10.0.1.5:5900"
Also make sure your .desktop file is executable. chmod +x your_file.desktop
Sander
  • 424
Adding
Path=/path/to/directory
may be required if the application requires the user to start the executable binary in a certain directory. That was the case for me when just compiling a program from source but not installing system-wide.
hg8
  • 13,582
