12
I use ubuntu 11.04.
My boost version:
  sam@sam:~/code/ros/pcl$ apt-cache  showpkg libboost-all-dev
  Package: libboost-all-dev
  Versions:
  1.42.0.1ubuntu1 (/var/lib/apt/lists/tw.archive.ubuntu.com_ubuntu_dists_natty_universe_binary-amd64_Packages) (/var/lib/dpkg/status)
   Description Language:
                   File: /var/lib/apt/lists/tw.archive.ubuntu.com_ubuntu_dists_natty_universe_binary-amd64_Packages
                    MD5: 72efad05a3c79394c125b79e1d4eb3a7
  Reverse Depends:
    libvtk5-dev,libboost-all-dev
    libfeel++-dev,libboost-all-dev
  Dependencies:
  1.42.0.1ubuntu1 - libboost-dev (0 (null)) libboost-date-time-dev (0 (null)) libboost-filesystem-dev (0 (null)) libboost-graph-dev (0 (null)) libboost-iostreams-dev (0 (null)) libboost-math-dev (0 (null)) libboost-program-options-dev (0 (null)) libboost-python-dev (0 (null)) libboost-regex-dev (0 (null)) libboost-serialization-dev (0 (null)) libboost-signals-dev (0 (null)) libboost-system-dev (0 (null)) libboost-test-dev (0 (null)) libboost-thread-dev (0 (null)) libboost-wave-dev (0 (null))
  Provides:
  1.42.0.1ubuntu1 -
  Reverse Provides:
How to upgrade boost to 1.44+ by using apt tools?
Thank you~
When I run apt-add-repository,it shows:
  sam@sam:~/code/ros/pcl$ sudo apt-add-repository ppa:timklingt/ppa
  Error reading https://launchpad.net/api/1.0/~timklingt/+archive/ppa: GnuTLS recv error (-9): A TLS packet with unexpected length was received.
How to fix it?
Thank you~
I try to install libboost1.46-all-dev:
  sam@sam:~/code/ros/pcl$ sudo apt-get install libboost1.46-all-dev
  Reading package lists... Done
  Building dependency tree
   libboost1.46-all-dev : Depends: libboost1.46-dev but it is not going to be installed
                          Depends: libboost-date-time1.46-dev but it is not going to be installed
                          Depends: libboost-filesystem1.46-dev but it is not going to be installed
                          Depends: libboost-graph1.46-dev but it is not going to be installed
                          Depends: libboost-iostreams1.46-dev but it is not going to be installed
                          Depends: libboost-math1.46-dev but it is not going to be installed
                          Depends: libboost-program-options1.46-dev but it is not going to be installed
                          Depends: libboost-python1.46-dev but it is not going to be installed
                          Depends: libboost-regex1.46-dev but it is not going to be installed
                          Depends: libboost-serialization1.46-dev but it is not going to be installed
                          Depends: libboost-signals1.46-dev but it is not going to be installed
                          Depends: libboost-system1.46-dev but it is not going to be installed
                          Depends: libboost-test1.46-dev but it is not going to be installed
                          Depends: libboost-thread1.46-dev but it is not going to be installed
                          Depends: libboost-wave1.46-dev but it is not going to be installed
  E: Broken packages
What's these error means?
And how to solve it?
Thank you~
sam
  • 6,921
EDIT: Boost-latest is not being updated since 2014 and the latest version on it is 1.55
The boost-latest PPA contains all the versions of libboost and fixed it for me!
sudo add-apt-repository ppa:boost-latest/ppa
sudo apt-get update
now you can install the version you desire, the latest at the time of writing is 1.55:
sudo apt-get install libboost1X.55-all-dev
Hakaishin
  • 386
Unfortunately, the latest official version of boost available in the repositories for Natty (11.04) is 1.42.
You can try installing it from an unofficial PPA, for example this one.
sudo apt-get update
ish
  • 141,990
