11
I'm trying to install tomcat 7 on Ubuntu Server 12.04 with:
sudo apt-get install tomcat7
which most sites and guides tell to do, but immediately I receive this answer:
Reading package lists... Done
Building dependency tree
Some packages could not be installed.
This may mean that you have  requested an impossible situation or
if you are using the unstable distribution that some required packages
have not yet been created or been moved out of Incoming.
The following information may help to resolve the situation.
tomcat7 : Depends: tomcat7-common (>= 7.0.26-1ubuntu1.1) but it is not
going to be installed
E: Unable to correct problems, you have held broken packages
What does this mean?
I've tried updating the repositories, changing them of country, repairing broken-packages.
I know there is the possibility of manual installation but this should be working easily
Any leads on this are greatly appreciated!
Peachy
  • 7,235
  • 40
  • 47
Anibaru
  • 111
This is because the package tomcat6-common is still residing in the system.
do this
sudo apt-get remove tomcat6-common
This will remove the conflicting package. Installing Tomcat7 Should work fine now
Rishin
  • 101
I had the same problem and I haven't tomcat 6 installed on my system before. I fixed it by manually installing libtomcat7-java. (At first I want to install tomcat7-common manually and it complains about libtomcat7-java)
Meysam
  • 141
Check which packages you had on hold for apt-get, you should use
sudo dpkg --get-selections | grep hold
The “hold” package state for apt-get can be changed using:
sudo echo package_name hold | dpkg --set-selections
Replace hold with install to unset the “hold” state
sudo apt-get update
And then try to install it again.
Peachy
  • 7,235
  • 40
  • 47
LnxSlck
  • 12,456
I found that I had previously installed Tomcat 6, which was conflicting but not being picked up for some reason.
Yusufk
  • 111
