Every time I try to use openjdk java 7, nothing happens. I try 6, and still, no response.
So, i tried removing it with Ubuntu Software Center. Every time I click on "Remove", it appears to remove it, but then the other version automatically downloads.
For example, I remove openjdk java 6, and java 7 (with all the add-ons) downloads onto my computer. I go to delete that, and once 7 is removed, version 6 reinstalls automatically, with all the add-ons.
Anyone know where i can stop the automatic downloads so I can re-install openjdk java, and get my programs to run again?
Mateo
  • 8,152
Jon S.
Something you installed is depending on Java (usually the package java-common). So you've got to have either one installed. You could also use Oracles Java packages (e.g. using this method). Then you can remove all OpenJDK (and IcedTea) packages like this:
sudo apt-get purge openjdk* icedtea*
You will keep the java-common package because Java is now provided by the sun-java* packages. If you want to entirely remove Java (and see which packages depend on it), try removing java-common.
mniess
  • 10,904
