I have installed Ubuntu 12.04 64-bit on my Asus K43SM Laptop with NVIDIA GeForce GT 630M. I am having trouble connecting another monitor (Samsung SMS19A100) as I don't know where to start the configuration. I have read about editing xorg.conf but I am still not familiar with it and it may be very risky. Need help. Thanks.
[EDIT] btw, I am planning to use TwinView, but I still need more details from the experienced. :P
edgar
  • 103
If you have installed the nvidia drivers for your graphics card (use the Additional Drivers tool to install them if not) you should have a tool NVIDIA X Server Settings in your menu (nvidia-settings in the Terminal). This has lots of options, but you should only need the second entry (X Server Display Configuration) which has a graphical interface for setting up twin monitors.
Once you have the configuration you want, the Save to X Configuration File button (your password will be required) will make this configuration permanent (otherwise you'll be back to a single screen the next time you restart).
crenshaw-dev
  • 32,852
chronitis
  • 12,647
Your additional driver tab should not have any drivers available for the graphics card. Even if it is available, please don't install. Its because nvidia linux driver doesn't support optimus.
Please don't install nvidia drivers from nvidia site either. It will cause black screen/ distorted screen or lower graphics resolution.
You should install bumblebee.
Before proceeding installation I would suggest to read the discussions
Is a NVIDIA GeForce with Optimus Technology supported by Ubuntu?
How well will Nvidia Optimus cards be supported in 12.04?
https://github.com/Bumblebee-Project/Bumblebee/wiki/FAQ
For multi moniter setup keep reading
https://github.com/Bumblebee-Project/Bumblebee/wiki/Multi-monitor-setup
Web-E
  • 21,716
