I have PC (with ubuntu 12.04) connected to LAN with 100 Mbps internet speed. I created wifi hotspot on my pc with wireless usb adapter TP Link tl-wn722n, which allows up to 150 Mbps speed. With my Asus Transformer pad (tablet) I manage to connect to this wifi hotspot and it says I have excellent, 54 Mbps speed. But when I test actual speed I get 0,8 Mbps download speed and 10 Mbps upload speed.
Why is my download speed so low?
Update: I tried internet connection in windows (I have dual boot) - I get download speed 30 Mbps and upload speed 18 Mbps...
So it's obviously ubuntu that's causing slower speeds (both)...
Jorge Castro
  • 73,717
Mersault
  • 287
You have confused between local network speed and internet speed.
There are different specification for networking instrument.
I am assuming that you have some kind of modem / router in your home. The ISP connects to it.
  • The modem/router and your computer Ethernet port have capability of handling 100mbps. So when you connect to it. it shows as 100mbps connection. This is between your router and your computer ethernet port.
  • Similarly your router wireless transmitter (inside the roter) is capable of 150mbps. The asus tablet receiver has capability of 54mbps. So it connects at speed of 54mbps.
  1. Why two wireless device has different speed?
    Its depends on hardware. There are different standard for wireless. You can read in detail over here.
  2. Why I am getting 8 MBps (there's a big difference between small b and big B) speed as download speed
    This is the real speed your ISP provides. From your computer to router its 100mbps. But after router is controlled by ISP.
    So its upto your plan. If download speed (as shown in download managers)is 8 MBps [means 8 mega bytes (not mega bits) per seconds] it can be said your internet plan's allotted network speed is 8*8 = 64 mbps. (this is mega bit, 8 bit = 1 byte)
If your network speed is 8 mbps, then in download managers it would show 8/8 = 1 MBPS
Web-E
  • 21,716
Is the wifi-chip from Intel? If so you may be experiencing this bug:
https://bugs.launchpad.net/ubuntu/+source/linux/+bug/836250
Creating a file /etc/modprobe.d/iwlwifi.conf containing
options iwlwifi 11n_disable=1 led_mode=1 swcrypto=1
helped in my case.
