Possible Duplicate:
Installing Ubuntu with Windows, which is left and right when allocating space?
I am installing 12.04 from a CD on a computer with an existing Windows XP installation, which I would like to keep in case my mom can't handle Ubuntu. The problem is this:
When selecting "Install Ubuntu alongside them", the next screen gives me a choice of selecting a drive (there is only one), and "Allocate drive space by dragging the divider below:", with two unlabeled partitions. Their sizes are shown, but their content is a mystery. Between the two sub-partitions (49.3 + 32.0 GB), it's just about the entire hard drive (82.3).
My question is this: is Ubuntu about to erase the Windows installation? Do I have to use the advanced partitioning tool? I would love to assume that one of these partitions will be given to Windows XP and the other to Ubuntu, but as they are not labeled, I am at a loss.
In most of the scenario Windows XP will be installed in the first primary partition C:Drive.When you choose "Install Ubuntu alongside with Windows" Ubuntu will also be installed in the same partition. For Installing Ubuntu you need only 4.5GB but as you have 50GB space in your Windows partition you can give 10-12GB for Ubuntu. This is very simple process. If you want to create a custom partition layout. I will suggest you to copy all your data on the second partition to an external hard disk and then delete the partition. Then reboot the system with the CD and select the installation option "Something else" and create a primary partition for root file system(mount point /, file system ext4) that is 10-12GB. Leave the rest of the space as it is, which you can partition in Windows(Disk management) and this will be available in Ubuntu too. No need to crate a swap partition if you have enough RAM, and u can create swap Partition even after installation :)
Vinod
  • 39
If you are not able to recognize partition. Then Abort installation. reboot your pc with windows. Check the Drives sizes. remember that Windows eats about 4 GB as for a paging so recognize carefully.
Example: In Windows 7 partitions are
C: 99Gb
D: 99gb
E: 49Gb
Linux can show this partitions as below
sda1/  103 GB
sda2/  103 GB
sda3/  53 GB
Note that which partition is big Windows C: or created New by you. and starts Installation again. Select partition carefully.
jokerdino
  • 41,732
KK Patel
  • 19,753
I had the same problem. Ultimately, I booted into windows to fix it. I downloaded a partition tool called "easeus", and used it to format the free space to ext3. When I booted Ubuntu again from the Ubuntu CD, it recognized this partition, and I could be sure that I was not over-writing Windows.
There are several other free Windows applications to deal with partitions, but I chose that one because of the Linux support. It worked as it should.
belacqua
  • 23,540
