I have installed JDK and JRE from this tutorial and have tried many methods of starting it up, yet my results are always the same. If any one could please help me I would be very grateful.
Exception in thread "Thread-3" java.lang.UnsatisfiedLinkError: /home/dennis/.minecraft/bin/natives/liblwjgl.so: /home/dennis/.minecraft/bin/natives/liblwjgl.so: wrong ELF class: ELFCLASS32 (Possible cause: architecture word width mismatch)
    at java.lang.ClassLoader$NativeLibrary.load(Native Method)
    at java.lang.ClassLoader.loadLibrary1(Unknown Source)
    at java.lang.ClassLoader.loadLibrary0(Unknown Source)
    at java.lang.ClassLoader.loadLibrary(Unknown Source)
    at java.lang.Runtime.load0(Unknown Source)
    at java.lang.System.load(Unknown Source)
    at org.lwjgl.Sys$1.run(Sys.java:69)
    at java.security.AccessController.doPrivileged(Native Method)
    at org.lwjgl.Sys.doLoadLibrary(Sys.java:65)
    at org.lwjgl.Sys.loadLibrary(Sys.java:81)
    at org.lwjgl.Sys.<clinit>(Sys.java:98)
    at net.minecraft.client.Minecraft.F(SourceFile:1853)
    at aoe.<init>(SourceFile:20)
    at net.minecraft.client.Minecraft.<init>(SourceFile:77)
    at anv.<init>(SourceFile:36)
    at net.minecraft.client.MinecraftApplet.init(SourceFile:36)
    at net.minecraft.Launcher.replace(Launcher.java:136)
    at net.minecraft.Launcher$1.run(Launcher.java:79)
Elijah Lynn
  • 3,928
Dennis
  • 71
7 Answers7
I play minecraft and I fixed the issue by: Using oracles version of java by using the wepupd8 teams java ppa. Follow this tutorial: http://www.ubuntugeek.com/how-to-install-oracle-java-7-in-ubuntu-12-04.html
Then try this in terminal
export LD_LIBRARY_PATH="/usr/lib/jvm/java-7-oracle/jre/lib/i386"
And then:
java -jar technic-launcher-latest.jar
If that doesnt work for you, you will have to update your jwgl files by following this tutorial I wrote (included references at bottom if you would rather use them):
Programster
  • 6,039
Install OpenJDK Java 7
sudo apt-get install openjdk-7-jre
Then download the latest copy of LWJGL from here http://lwjgl.org/download.php and extract it
Copy the following to ~/.minecraft/bin
  • jinput.jar
  • lwjgl.jar
  • lwjgl_util.jar
And the following to ~/.minecraft/bin/natives
  • libjinput-linux.so
  • libjinput-linux64.so
  • liblwjgl.so
  • liblwjgl64.so
  • libopenal.so
  • libopenal64.so
Then restart Minecraft
Make sure you overwrite the files that Minecraft downloads, they are out of date.
vassie
  • 191
Instead of doing as the other post suggests, my cousin was kind enough to inform me of this option(source) found by searching specifically for my distro, but which will work with others having this same issue as well. Part of the problem was already solved by running the following from terminal.
If using java 7:
export LD_LIBRARY_PATH="/usr/lib64/jvm/java-1.7.0-openjdk-1.7.0/jre/lib/amd64/"
If not using java 7 you should be able to find the variable on google fairly easy, for java 6 for example you might try:
export LD_LIBRARY_PATH="/usr/lib64/jvm/java-1.6.0-openjdk-1.6.0/jre/lib/amd64/"
Now that should work but it didn't, so after reading the post above I decided to do as suggested and add to ~/.bashrc Adding anywhere in the file will be fine just copy and paste the above using gedit or nano:
gnomesu gedit ~/.bashrc
Now save or Ctrl + s and close gedit and then run the following to update bash:
source ~/.bashrc
Try running minecraft again and you should be set.
l300lvl
  • 1,192
Try install proprietary drivers.
That helped me.
Search for additional drivers in the Unity Dash.
Eliah Kagan
  • 119,640
Install the Oracle Java client, or if your using that and having problems, try the OpenJRE.
Then, most important, you need to do this:
http://www.minecraftwiki.net/wiki/Tutorials/Update_LWJGL
That got me up and running.
Make sure you install version 6 of OpenJDK if you use it. Minecraft has issues running with OpenJDK 7. It would be best if you install Sun Java instead.
I got the same wrong ELF class: ELFCLASS32 error, and after upgrading LWJGL to 2.8.4 Minecraft 1.3.2 worked for me with Oracle Java 1.7.0_07 and OpenJDK 6 on Ubuntu 12.04 x86_64.
You can change the java executable with sudo update-alternatives --config java.
l0b0
  • 9,271
