Zeitgeist logs your activity in Unity. Is there a way to look at the raw logs it creates?
The logs are stored in ~/.local/share/zeitgeist/activity.sqlite. They are stored in an SQLite database, so you will need an SQLite database browser to view them.
- 16,403
Yes, Zeitgeist stores its data in sqlite. I'm using Ubuntu 12.04 (Precise Pangolin) and my zeitgeist usage data is in
In order to access the raw logs, you'll need to know some SQL, which I'll leave up to you. However, if you have not installed sqlite3
, the command line interface for SQLite Version 3, then do so
sudo apt-get install sqlite3
Then, you may interogate the raw data as follows
[11:33:50 oyrm zeitgeist]$ pwd # Just to show where we are
/home/oyrm/.local/share/zeitgeist
[11:33:54 oyrm zeitgeist]$ sqlite3 -interactive activity.sqlite
SQLite version 3.7.9 2011-11-01 00:52:41
Enter ".help" for instructions
Enter SQL statements terminated with a ";"
sqlite> .tables
actor extensions_conf mimetype storage
event interpretation payload text
event_view manifestation schema_version uri
sqlite>
As you can see, I have access to the activity.sqlite database at this point and may execute SQL to my hearts content. Now, figuring out how these are all related will be a puzzle for you, but you can use sqlite3 to determine useful things like db and table schemas.
