I have 11.10 and Windows 7 in dual boot. Today I tried to update grub and I run the following command in terminal:
sudo fdisk -l
sudo mount /dev/sda6 /mnt
sudo grub-install --root-directory=/mnt /dev/sda
sudo grub-install
After installation and reboot, it does not show the grub menu (from which I can choose which OS to boot) and it directly boots Ubuntu.
Please help.
Peachy
  • 7,235
  • 40
  • 47
Boot to your live cd.
Then: in a terminal type.........
sudo mount /dev/sdXY
Example:
sudo mount /dev/sda1
Run the grub-install command as described below. This will reinstall the GRUB 2 files on the mounted partition to the proper location and to the MBR of the designated device.
sudo grub-install --root-directory=/mnt /dev/sdX
Example:
Refresh the GRUB 2 menu with
sudo update-grub.
reboot
If this does not work for you - try the link bellow.
https://launchpad.net/boot-repair
Malee
  • 221
