Possible Duplicate:
Upgrading ubuntu with some thing which can make more than one connection
I'm using Ubuntu 11.10 and I want to download all (for a specified installation) packages simultaneously and in chunks (as in jDownloader) for faster downloading speed. I wanted this because my shared internet connection has no internet load balancing mechanism. I'm using my closest mirror mirror.learn.ac.lk/ubuntu (Sri Lanka).
I've used Ubuntu Software Center, Synaptic Package Manager, apt-get and some other package managers to download packages. All of them are using a single connection for all packages which causes slow download (in my connection).
Is it possible to or is there a way to,
  • install an application to handle package downloads of any Package Manager (even in Update Manager) in simultaneous connections
  • find a Package Manager specifically designed for slow connections (uses simultaneous connections in downloads)
  • if above are impossible
    1. get a list of required packages' URLs
    2. manually download (using a Download Accelerator)
    3. move *.deb to /var/cache/apt/archives
    4. install packages
Please tell if you have a better way
I'm not expert with source code modifying and compiling. So please do not give that kind of answers
I just want to know what is possible and what is the procedure.
Naveen
  • 105
You can try Apt-fast.
Apt-fast is a shellscript wrapper for apt-get that improves one's apt-get download speed by simultaneously downloading packages with multiple connections per package.
sudo add-apt-repository ppa:apt-fast/stable -y && sudo apt-get update
sudo apt-get install axel apt-fast
After setting it up, you can use it, just like apt-get
sudo apt-get update
Will be:
sudo apt-fast update
sudo apt-get install chromium-browser
Will be:
sudo apt-fast install chromium-browser
LnxSlck
  • 12,456
Yes, You can generate a package download script and then download those packages using a download manager.
  1. Generate a download script
    For example: If you want to install package eclipse, use this command to generate a package download list in a file download-list
    sudo apt-get install --allow-unauthenticated -y  --print-uris eclipse | grep http | cut -d \' -f2 > download-list
    Replace the name eclipse with your desired package. If your mirror is an ftp mirror, replace http with ftp.
  2. Then install a download manager. I'd recommend to install aria2
    install command: sudo apt-get install aria2
  3. Download all files
    Create a folder in your home, Name it, packages. Copy the download-list file in that folder. Then open a terminal by pressing Ctrl-Alt-T. Go the the packages folder by the command, cd packages. Then do this command to download all files:
     aria2 -i download-list
    It will download all files in that folder
  4. Setup local repo
    Then in the same packages folder, Do this command and wait until it finished.
    apt-ftparchive packages . > Packages
    Then open /etc/apt/sources.list file with command: gksu gedit /etc/apt/sources.list
    At the top of the file, write this line:
    deb file:/home/your-user-name-here/packages /
    Save the file and exit. remember to replace your-user-name-here with your actual login name
  5. Install the package
    To install the package now, use these command:
    sudo apt-get update to refresh package database. and then
    sudo apt-get install --allow-unauthenticated eclipse
    replace, eclipse with actual package name.
For any time to install other package, first generate the download list, download those packages, put them into the packages folder and run the command in step 4, and do the commands in step 5.
Anwar
  • 77,855
