I have installed OpenMPI and a package called CVODE onto my Ubuntu system, which is running in a virtual machine (using VirtualBox). There was one problem which was worked around by copying some library files to /usr/lib. In other words, the following happened when I tried the example programs that came with CVODE:
$ mpirun ./cvAdvDiff_bnd
cvAdvDiff_bnd: error while loading shared libraries: libsundials_cvode.so.1: cannot open shared object file: No such file or directory
$ sudo cp /home/jeff/sundials/instdir/lib/libsundials_cvode.so.1 /usr/lib/libsundials_cvode.so.1
$ mpirun cvAdvDiff_bnd
cvAdvDiff_bnd: error while loading shared libraries: libsundials_nvecserial.so.0: cannot open shared object file: No such file or directory
$ sudo cp /home/jeff/sundials/instdir/lib/libsundials_nvecserial.so.0 /usr/lib/libsundials_nvecserial.so.0
2-D Advection-Diffusion Equation
Mesh dimensions = 10 X 5
Total system size = 50
Tolerance parameters: reltol = 0 abstol = 1e-05
At t = 0 max.norm(u) = 8.954716e+01
At t = 0.10 max.norm(u) = 4.132889e+00 nst = 85
At t = 0.20 max.norm(u) = 1.039294e+00 nst = 103
At t = 0.30 max.norm(u) = 2.979829e-01 nst = 113
At t = 0.40 max.norm(u) = 8.765774e-02 nst = 120
At t = 0.50 max.norm(u) = 2.625637e-02 nst = 126
At t = 0.60 max.norm(u) = 7.830425e-03 nst = 130
At t = 0.70 max.norm(u) = 2.329387e-03 nst = 134
At t = 0.80 max.norm(u) = 6.953434e-04 nst = 137
At t = 0.90 max.norm(u) = 2.115983e-04 nst = 140
At t = 1.00 max.norm(u) = 6.556853e-05 nst = 142
Final Statistics:
nst = 142 nfe = 174 nsetups = 23 nfeLS = 0 nje = 3
nni = 170 ncfn = 0 netf = 3
The problems finding those two files were solved by copying them to /usr/lib. However, there are hundreds of files in ~/sundials/instdir/lib/.
How can I get Ubuntu to look for those files in their current location instead of copying them all to /usr/lib/?
