I have installed Nagios in my ec2 server. Now I want to install check_snmp plugin. I found that this is not available in :
/usr/local/nagios/libexec
I tried :
sudo apt-get install nagios-plugins-snmp
But I'm getting :
E: Unable to locate package nagios-plugins-snmp
How can I install the plugins?
Thanks in advance.
Jason C
  • 948
batman
  • 8,071
This is in the nagios-plugins-standard package. I'd suggest installing the nagios-plugins package, as that will install it, as well as the nagios-plugins-basic package:
Then, your SNMP plugin will be available in:
/usr/lib/nagios/plugins/check_snmp
Jeremy Kerr
  • 27,829
On your monitoring server:
All standarded plugins will be installed in
Not in
/usr/lib/nagios3/
Please see Nagios - Official Ubuntu Documentation in the section of "Configuration Overview"
Then in
/etc/nagios-plugins/config/
you will find snap.cfg, which assigns each command_line a correspondent command_name.
For example
define command{
    command_name    snmp_load
    command_line    /usr/lib/nagios/plugins/check_snmp -H '$HOSTADDRESS$' -C '$ARG1$' -o .$
peizhao
  • 141
I had this same issue and found the problem.
The point is that when you have installed the nagios-plugins, you shouldn't had net-snmp and net-snmp-utils packages installed at all. And thats why check_snmp were not compiled.
For fix this, you have to install net-snmp and net-snmp-utils and after that compile/install nagios-plugins again.
FYI: copy paste from another forum Ahmed
Thomas
  • 6,433
If you install nagios 4 following this tutorial, then your installation directory is /usr/local/nagios.
On starting nagios and browsing to nagios admin portal, you could see the following errors
 - (No output on stdout) stderr:
   execvp(/usr/local/nagios/libexec/check_ping
   execvp(/usr/local/nagios/libexec/check_users
   execvp(/usr/local/nagios/libexec/check_http
This is how I fixed the above errors,
Install plugins
This will install all plugins to /usr/lib/nagios/plugins directory.
Just copy all files starting with check_* to /usr/local/nginx/libexec.
cp /usr/lib/nagios/plugins/check_* /usr/local/nagios/libexec
and wait for nagios to reload/refresh browser window
Gryu
  • 8,002
  • 37
  • 53
Kenshin
  • 251
