Ubuntu fails to boot. (It was working fine for the last moth.)
Selecting "recovery mode" shows the message:
fb: conflicting fb hw usage inteldrmfb vs EFI VGA - removing generic driver
However, after this message is shown, the system still does not boot.
Jorge Castro
  • 73,717
8128
  • 28,868
  1. Whilst on the GRUB selection screen (where you select your operating system, recovery mode, etc) use the arrow keys to navigate to the normal boot entry, bur rather than pressing enter, press the letter 'e'.
  2. Delete the line gfxmode $linux_gfx_mode
  3. Press F10 to boot
If this doesn't work, try again, but first disconnect all USB devices (other than keyboard!) and extra monitors if you have them.
If you can not reboot, once booted, run the following, so that hopefully you won't have to do the steps above everytime you boot.
sudo grub-install
sudo update-grub
8128
  • 28,868
While trying to install linux mint 17, I stuck in the same problem. In my case there was no gfxmode $linux_gfx_mode line in grub so what I did is to add nomodeset BEFORE quiet splash.
Check that https://askubuntu.com/a/207177/34553 for what nomodeset is.
vasilakisfil
  • 141
I solved this by editing /etc/grub.d/10_linux
there is an if clause that writes the line:
pl_rock
  • 11,715
