I am a first time user of Ubuntu. I recently installed it as a dualboot with Windows 7. I have Logitech USB speakers which work fine in Windows. However, I can't get any audio to play in Ubuntu. Any help would be appreciated.
Here is an output from the Terminal:
home@ubuntu:~$ aplay -l
**** List of PLAYBACK Hardware Devices ****
card 0: Intel [HDA Intel], device 0: ALC887 Analog [ALC887 Analog]
  Subdevices: 1/1
  Subdevice #0: subdevice #0
card 0: Intel [HDA Intel], device 3: HDMI 0 [HDMI 0]
  Subdevices: 1/1
card 1: AUDIO [USB  AUDIO], device 0: USB Audio [USB Audio]
  Subdevices: 0/1
Jack
  • 41
Open system setting then go to sound and under the hardware tab you should find your speakers if you dont know which one to choose then just click test and keep trying you wont ddamage your system.
Mark Kirby
  • 18,949
  • 19
  • 79
  • 116
If you're trying to set these as default, please refer to this question - 16.04 Headphones detected, but not switched on automatically after startup
James
  • 311
Install Veromix. Start the application and select the device you want to use as the default device.
