For a while I have the problem mentioned in the title. Update is stuck on pre-configuring packages without any other error. I tried almost everything I've found searching Google, but it didn't solve my problem.
btw
sudo apt-get update
sudo apt-get autoclean
sudo apt-get clean
sudo apt-get autoremove
sudo apt-get update && sudo apt-get upgrade
is not working. Can somebody please help me fix this issue?
Peachy
  • 7,235
  • 40
  • 47
Daniel
Open up top, press V to enable tree view, and find the leaf process under xenial -> xenial -> sh -> dpkg-preconfigre -> ... -> blocking leaf process. Then kill (softly) this process:
sudo kill -s SIGTERM {process_id}
In my case, it was grep waiting for something that clearly wasn't coming.
ostrokach
  • 864
I noticed that a mysql process was starting every time I tried to upgrade and it was eating all of one of my processors. That same process stopped after I stopped the upgrade process. I was unable to determine the cause of that mysql process being stuck so I followed the advice from here: "Failed to spawn mysql main process: unable to execute: No such file or directory".
Then, after running apt-get upgrade it worked without a problem.
Hope this helps.
Stefan
  1. Cleaning using two ways command. sudo apt-get clean && sudo apt-get update
  2. dpkg --configure -a
  3. apt-get install -f The last command will help you to remove all broken package.
  4. sudo apt-get update && sudo apt-get upgrade
  5. reboot pc
  6. Install the rest of the package through update-manager.
hope it helps
Erick
  • 31
